hotwaterwizard
2,022 -
Posts posted by hotwaterwizard
Most test conditions are presented with set values for the components.
This gives you a standard in which you can figure out other conditions with different component values. If you did not have the example to go by the math for figuring other conditions would be a bit more difficult. -
I also found a BIN file but I have no idea how to open a BIN file.
http://www.eserviceinfo.com/download.php?fileid=4393 -
Hynix HY27US08121A NAND flash chip
Datasheet
http://www.hynix.com/datasheet/pdf/flash/HY27(U_S)S(08_16)121A%20Series(Rev1.1).pdf
Cross Parts
http://www.memotech.co.uk/xref/xrefframe.asp
CONFIGURATION 64M X 8
HYNIX HY27US08121A
SAMSUNG K9F1208U
TOSHIBA TC58DVM92A
TX2 Datasheet Attached
Search Results
TX-2 40816229 IC Datasheet -
CA309
HA274
MC3476P1
NTE996
http://www.powerdesigners.com/InfoWeb/design_center/Appnotes_Archive/an6048.pdf
http://www.powerdesigners.com/InfoWeb/design_center/Appnotes_Archive/an6077.pdf
http://www.ee.washington.edu/stores/DataSheets/linear/ca3080.pdf
http://www.till.com/blog/archives/2005/06/last_of_the_ota.html -
Not a good number check here http://www.mouser.com/catalog/625/95.pdf
All I can find is M52307
Here is the Datasheet.
Here are a few links i found on Google.
Try it yourself you can find many more.
Datasheets
http://www.national.com/ds/CD/CD4093BC.pdf
http://users.pandora.be/on4ldz/Lightning/data_sheet/CD4093.pdf
http://noel.feld.cvut.cz/hw/motorola/books/dl131/pdf/mc14093brev3.pdf
Application notes
http://online.sfsu.edu/~sfranco/CoursesAndLabs/Labs/453LabsPDF/453Lab3.pdf
http://hyperphysics.phy-astr.gsu.edu/HBASE/electronic/schmitt.html
http://www.ee.ttu.edu/lab/robot/hyster.htm
http://en.wikipedia.org/wiki/Schmitt_trigger
http://www.musicfromouterspace.com/analogsynth/mmlogic.html
http://www.answers.com/topic/schmitt-trigger -
TA8659n is a Jungle IC
Here is a Datasheet for a Simular IC.
TA8759BN [attachment deleted by admin] -
LA4227 Having trouble with the pinout but I was told the Pinout of LA4627 is the same but the specs are different.
The specs are here. http://service.semic.sanyo.co.jp/semi/eng/search/property.asp?PROD=LA4227&CLCD=15 -
How about a running message sign
220volts?
I Found this.
http://www.cndzz.com/info/2488-1.htm
http://www.mculand.com/e/sub2/sam4_app/1_basic_timer.pdf -
3 Phase Motor Control
TPIC43T02 Datasheet
http://focus.ti.com/lit/ds/symlink/tpic43t02.pdf
Steper Control
http://www.cs.uiowa.edu/~jones/step/circuits.html
3 phase converter
http://www.metalwebnews.com/howto/ph-conv/ph-conv.html -
Hmmm Which one to choose?
http://www.crowbusters.com/recipes.htm
http://www.thecrowroost.com/RECIPES.htm
http://www.cooks.com/rec/search/0,1-0,crow,FF.html
http://bertc.com/crow_casserole.htm
http://bertc.com/three_crows.htm
http://www.idahostatesman.com/apps/pbcs.dll/article?AID=/20041216/IDOUT/412160333/1136/IDOUT
Mabe This one?
Crow Pie
1 crow
stuffing of your choice
salt and pepper
shortening
flour
2 Pie crust mixes
2-3 hard-boiled eggs
Stuff the crow. Loosen joints with a knife but do not cut through.
Simmer the crow in a stew-pan, with enough water to cover, until
nearly tender, then season with salt and pepper. Remove meat from
bones and set aside.
Prepare pie crusts as directed. (Do not bake)
Make a medium thick gravy with flour, shortening, and juices in
which the crow has cooked and let cool.
Line a pie plate with pie crust and line with slices of hard-boiled
egg. Place crow meat on top. Layer gravy over the crow. Place
second pie dough crust over top.
Bake at 450 degrees for 1/2 hour. -
It is only in the search Database but the Datasheet can not be found. Try downloading it it is not there.
http://kazus.info/datasheets/search/go/?query=CD5954CB&nohistory=1&h=1
Nope Nothing there.
Sorry to come off so strong but it bothers me when people make comments and say it took a few seconds on Google but, the Datasheet is nowhere to be found.
If it is there then I challange you to Upload the Datasheet Here.
You will then see me eat crow on my previous comments. -
Page 14 states LM353 = LF358
http://www.elektronka.com/download/doc/tablica_ekvivalenata.pdf
DATASHEETS
http://www.fairchildsemi.com/ds/LF%2FLF353.pdf
http://www.cs.cmu.edu/~RAS/old/DataSheets/LF353.pdf
http://www.st.com/stonline/products/literature/ds/2153.pdf -
you sure it is not sn7416?
The best I could do is a schematic using this IC [attachment deleted by admin]
Understanding test conditions in any Datasheet
in Datasheet/Parts requests
Posted
Here is another related link.
http://www.electronics-lab.com/forum/index.php?topic=5524.0
Hot to read Datasheets.
http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=5524.0;id=3874
