hotwaterwizard
2,022 -
Everything posted by hotwaterwizard
kdc-c800 http://www.mictronics.de/?page=cdc_proto#Kenwood pin direction description 1 O CH-REQH - Request output to changer; "Low" : Request 2 - Ground 3 - Vcc +12V 4 O CH-CON - Changer control; "High" : Operation mode "Low" : Standby 5 I CH-MUTE - Mute request from changer; "High" : Mute 6 - AGND - Audio Ground 7 O CH-RST - Reset output to changer 8 I Audio right channel 9 I CH-REQC - Request input from changer; "Low" : Request 10 I CH-DATAC - Data input from changer 11 O CH-DATAH - Data output to changer 12 I Audio left channel 13 I/O CH_CLK - Clock input/output for changer ftp://docs.kenwoodusa.com/manuals/OM-KDC-C800-1992-KUSA.pdf http://www.minidisc.org/manuals/kenwood_kmdps970r.pdf http://instrukcje.elektroda.net/caudins.htm
Search Results uPD6250C Sony KV2670R uPD6250 17x16 DIP16 uPD6250C NEC Remote Control Memory IC Troubleshooting Guide http://www.mainelectronics.com/servicetips/sonykv2670r.htm UPD62 Datasheet http://boss.iele.polsl.gliwice.pl/pdf/NEC/u14474ej2v0ds00.pdf App Note http://boss.iele.polsl.gliwice.pl/pdf/NEC/u11726ej1v1an00.pdf
datasheet for HA1392 needed
hotwaterwizard replied to Sukhbinder's topic in Datasheet/Parts requests
I Found the real Datasheet! HA1392.pdf -
HA1392 DUAL 4.7W POWER AMPLIFIER 12P ECG1606 ***USE HA1392*** -
http://www.pgmfi.org/twiki/bin/view/Library/Oki6260A
Is it better than the one posted? Please share.
Nice Pinout picture but, where does each pin go? It would be nice to know Power, Audio, Programing, Ect.
Not available yet try emailing NEC
Here are some more interesting Links. Parabolic Microphone http://ourworld.compuserve.com/homepages/G_Kunkel/microphone.htm http://ourworld.compuserve.com/homepages/G_Kunkel http://ourworld.compuserve.com/homepages/G_Kunkel/cardboard/cardboard.htm Cardboard Dish http://ourworld.compuserve.com/homepages/G_Kunkel/cardboard/cardboard.htm
here is another more powerful.
Here is an Inhanced View of yours
Will this work? HA1388.pdf
http://www.nteinc.com/specs/1300to1399/pdf/nte1389.pdf http://www.elektronika.sirius.pl/index.php?dzial=aplikacje&id=074 UPC1230H241026.pdf
The biggest was on a power pole but, it was only 2 ohms.
Here are some Telephone Links http://www.electronics-lab.com/projects/telephone/013/index.html http://www.electronics-lab.com/projects/telephone/014/ http://www.electronics-lab.com/projects/telephone/015/index.html http://www.electronics-lab.com/projects/telephone/016/index.html http://www.geocities.com/iecmaster/circuits_tel/cir_tel002.html http://www.ee.washington.edu/circuit_archive/circuits/F_ASCII_Schem_Tel.html#ASCIISCHEMTEL_010 http://www.geocities.com/iecmaster/circuits_tel/cir_tel007.html http://www.electronicsforu.com/efylinux/circuit/feb2003/Simple%20Telephone%20Ring%20Tone%20Generator.pdf http://www.techlib.com/electronics/telephone.html http://www.hotspot.freeserve.co.uk/HOTSPOT/TLS/tlsframe.htm http://www.hut.fi/Misc/Electronics/circuits/telephone_ringer.html
or if you have a couple of extra phones laying around.
Why not Make an Intercom.
LM383 TDA2002V UPC2002V ULN3701Z AE320 http://www.ozitronics.com/docs/k47.pdf http://www.alldatasheet.com/datasheet-pdf/view/NSC/LM383.html http://www.st.com/stonline/books/pdf/docs/1449.pdf http://members.tripod.com/~Malzev/comp/tda2002.htm
SD-1700A 6746 transistor replacement needed
hotwaterwizard replied to hns's topic in Datasheet/Parts requests
2sd1700 Datasheet 2sd1700.pdf -
Your name does not do you justice. I found the same project in 3 locations in my search for the Datasheet. Finally after hours of searching I read the Circuit Operation Details. Circuit Operation: IC1 is an Infra Red module. IR modulated pulses are received and buffered by this IC. It has a standard TTL output, the output with no signal is logic 1. One gate of a CMOS inverter and drives Red LED1 as a visible switching aid. Another gate buffers the signal and applies it to the time constant circuit, comprising R3,C2,R4 and D1. C2 charges via R3, and discharges via R4, D1 prevents quick discharge via the low output impedance of the CMOS buffer. I then realized the LED you seek is just a Visual Aide not anything special. A standard LED will do the job just fine. Here are my search Results. CQX35A CQX35A = TLHR5100 LTL4208=CQX35A LITEON 5Pie http://www.zen22142.zen.co.uk/Circuits/Interface/ir_switch.htm http://www.mitedu.freeserve.co.uk/Circuits/Interface/ir_switch.htm http://www.electronics-lab.com/projects/models/008/index.html TLHR5100 VISHAY/TE LTL4208 general purpose visible dome-style led LITEON LTL-4208-TN002 general purpose visible dome-style led LITEON
Tuff one I found others in the series but not that one. CQX48.pdf
looking for HM82C11C Datasheet
hotwaterwizard replied to kenkeeley's topic in Datasheet/Parts requests
How about this one? UM82C11-C.pdf -
Datasheet http://www.onsemi.com/pub/Collateral/MC34063A-D.PDF http://www.datasheetarchive.com/download.php?pi=118613 http://www.metatech.com.hk/datasheet/aic/dcdc_pdf/MC34063a.pdf http://www.fairchildsemi.com/pf/MC/MC34063A.html Discription Applications http://www.interq.or.jp/japan/se-inoue/e_ckt231.htm http://www.st.com/stonline/prodpres/standard/vregs/08vlt_1.htm#c1 Design Tool http://www.nomad.ee/micros/mc34063a/index.shtml
Here is the best I could do. I had to Download Eagle Then Download the Library Discribed above then Draw the Pinout in Paint then Convert it to GIF. Hope it helps.
http://groups.yahoo.com/group/mt13x9/ http://1389.zewan.com/ http://amstrad3016.altervista.org/ http://groups.yahoo.com/group/MEDIATEK1389/ http://www.delta.ee/xoro/_Reanimation_/mt1389%20serial%20interface%20gallery.pdf http://www.zxpilot.vladivostok.ru/temp/ROM%20Structure.txt http://forum.doom9.org/showthread.php?s=&threadid=67028 http://who.is.free.fr/wiki/index.php?Mediatek
