hotwaterwizard
Members
  • Posts
    2,022
  • Joined
  • Last visited
Everything posted by hotwaterwizard
  1. Exactly what are you wanting to do here? You Must Heatsink the components for 5 amps each if not they will only handle 1 amp each. There is another way to make a high current power supply.
  2. Not sure if this is what you need R-X1_SCH_rev6.rar
  3. it looks like a Doc Feeder Motor http://www.precisionroller.com/doc-feeder-parts-for-canon-dadf-k1/details_33863.html
  4. Do you have any more info on this assembly? It looks like it came out of an Encoder of some sort. The black wheel on the back side is like a rotary Encoder wheel. Google Search results Canon Precision motor CN38 http://www.canon-prec.co.jp/english/products/dcmotor/index.html http://www.canon-prec.co.jp/english/products/dcmotor/pdf/DC_Micro_MotorsE.pdf Canon Precision Encoder Motor http://www.tridenteng.co.uk/media/pdf41739466eadb3.pdf http://www.tridenteng.co.uk/media/pdf43030ed6f02e0.pdf
  5. Google search Results VARO VSK3040T TO-3 NSN # 5961-01-338-3618 ,5961-01-217-0614 VSK3040T N/A Center-Tapped Positive CC Schottky Rectifier CROSS Referance MCC MBR3040 http://download.siliconexpert.com/pdfs/source/qd/mco/mbr3020-mbr30100(to-3).pdf RECTRON SR3045C http://www.asukaele.co.jp/hp/rec/data/sr3020c-3060c.pdf Microsemi SD241HR2 http://www.microsemi.com/datasheets/WT2-48.PDF Shindengen S30SC4M http://www.datasheetcatalog.org/datasheet/Shindengen/mXqwqwu.pdf http://www.datasheetarchive.com/ VSK3040T Spec sheet Center-Tapped Positive CC Schottky Rectifier Various V(RRM)(V) Rep.Pk.Rev. Voltage=40 I(RM) Max.(A) Reverse Current=10m @V® (V)(Test Condition)=40 I(RM) Max.(A) Pk. Rev. Current=75m @Temp. (
  6. I can do it with WinRar but what a hastle 8.2 mb 3 files per post I figure about 28 files at 300kb and 10 x posting just to get them on here. Maybe I will go somewhere else to post my files and forget this place!!!!!!!
  7. 1 post for that guy. never replied back. what a waste of my time finding them for a ghost.
  8. Look in this file sc10_marking_codes_1999_1.pdf
  9. This is rediculous I have the Service Manual but this STUPID BOARD is set for 3000kb How many seperate files do I need for 8.2MB ????
  10. This topic has been moved to Service Manuals. [iurl]http://www.electronics-lab.com/forum/index.php?topic=19733.0[/iurl]
  11. http://www.freeservicemanuals.net
  12. Check all of your solder connections and voltages to the device. http://www.electronics-lab.com/projects/test/014/index.html http://users.otenet.gr/~meteo/project_led-display-digital-voltmeter.html
  13. Here are the other 2 DM74S288.pdf DM74S387.pdf
  14. Okay it took me a while but here is what I found. All 4 of them. 2 here and 2 more in the next post. DM74S188.pdf dm74S287.pdf
  15. 74188: 256-bit (32x8) Programmable read-only memory with open collector outputs 74287: 1024-bit (256x4) Programmable read-only memory with three-state outputs 74288: 256-bit (32x8) Programmable read-only memory with three-state outputs 74387: 1024-bit (256x4) Programmable read-only memory with open collector outputs
  16. Looks like Stuee lost interest in this post.
  17. http://www.kcdec.com/download/2008918111259.pdf http://parts.digikey.com/1/parts/989394-sensitive-gate-scr-0-8a-600v-low-ec103m2.html http://www.teccor.com/data/en/Data_Sheets/E5SensitiveSCR.pdf
  18. Here is a Diagram for the Reed Switch Idea The second is a Digital Matrix with Diodes to display a number for which gear you are in.
  19. I Googled it and it sent me streight back here. LOL ??? :) ;) :D ;D >:( :( :o 8) ::) :P :-[ :-X :-\ :-* :'(
  20. The model number would be helpful. Maybe these links will be helpful to you. http://www.repairfaq.org/sam/crtfaq.htm http://www.electronixandmore.com/project/7.html http://www.tone-lizard.com/Oscilloscopes.htm
  21. Google search Results M455E Ceramic Filter? http://www.alldatasheet.com/view.jsp?Searchword=M455E
  22. Possible Substitutes? http://kr.ic-on-line.cn/IOL/datasheet/actf45-48_4171619.pdf ACT_F45-48.pdf
