hotwaterwizard
2,022 -
Everything posted by hotwaterwizard
looking for HM82C11C Datasheet
hotwaterwizard replied to kenkeeley's topic in Datasheet/Parts requests
where did you find it. I have looked almost everywhere. -
Trying to identify/locate ICs
hotwaterwizard replied to GordonSmith's topic in Datasheet/Parts requests
I think you may be right. Compare for yourself. -
I don't see a 161 in this circuit. -
LA3161 and LA3221 Datasheets
hotwaterwizard replied to hotwaterwizard's topic in Datasheet/Parts requests
Here is another one. LA3161_Sanyo.pdf -
STR-D6108 is on this list http://www.ssg-de.com/ssg_html/german/uploads/akt2/2000-03-07%20Sanken%20Products%20Discont%20Notice.pdf
Need more info??? ???
Transistor, IC Diode, Capacitor, Resistor ?????????
I have been looking for it faithfully and have not found it yet.
increment/decrement counter
hotwaterwizard replied to GordonSmith's topic in Electronic Projects Design/Ideas
Look at this. http://www.interq.or.jp/japan/se-inoue/e_ckt14.htm -
I Need a 12v version of this.
Usually a varible speed Drill running real slow works well if you mount it in a vice. Run a screw and nut thru the core and put it in the drill. A Lathe works even better.
If we could figure out a way to use a button to increase voltage every time you push it and have a capacitor discharge timer to decrease the voltage slowly unless the button was pushed again we could use a Bargraph Display Driver like the LM3914 ,5 or 6 to do the job. Look at the Datasheet for more Ideas. http://www.national.com/ds/LM/LM3914.pdf http://www.national.com/ds/LM/LM3915.pdf http://www.national.com/ds/LM/LM3916.pdf -
Have you tried Emailing the Author? http://www.compulink.co.uk/~lasertag/lasertag.htm#diy -
Here are some other circuits to look at. http://www.lasertag.de/index.php3?i=tech http://homepage.ntlworld.com/sparta/lcbasic.pdf http://www.armory.com/~spcecdt/history/ModDescription.html http://www.myownlittleworld.org.uk/fiat-lux/technical_overview.htm http://www.1sourcelasertag.com/blank?pageid=9&catstart=0&prodstart=0 http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/s2002/cmp28/hard.html -
Look at these links. led counters The Last circuit is closest. If you use a switch debouncer circuit instead of the timer it will count up when you push the button . Use a delayed on timer with a reset triggered by the same debouncer for the down sequence then you will have your circuit. The only problem is resetting the whole circuit. I think you can just turn off the power to reset the sequence. ??? http://a402.phys.psu.edu/402/Exp/E8/E8.html http://www.interq.or.jp/japan/se-inoue/e_ckt14.htm http://www.geocities.com/lemagicien_2000/elecpage/bounlite/bounlight.html -
Variable Power Supply 0-24vdc 5A more...
hotwaterwizard replied to nabut's topic in Electronic Projects Design/Ideas
Here is one from another post in the Circuit Request Section. -
IR3To7 is a Preamp. CLICK HERE TAG GUN pdf It is not a Datasheet but it is helpful. -
Manufactures would be helpful. Sharp Toshiba? -
Request for MAXIM MAX232 datasheet
hotwaterwizard replied to cwt's topic in Datasheet/Parts requests
Here you Go! max232.pdf -
Ohhh Ahhh I like it I Love it I want Some more of it! ::)
I see it opened. I merged the Two as well.
Another one. http://www.microsemi.com/datasheets/2n3441.pdf And Another. http://www.semelab.co.uk/pdf/bipolar/2N3441.pdf
Request for 8x5 dot matrix array datasheet
Well I found a bunch of them at the website. I can Email them or you can go there and download them yourself. http://www.liteon.com.tw/databook/default.htm To navigate to the datasheets on the site : Look to the left side Box Click on LED Display Then Click on Dot Matrix Then Click on one of the blue Index Arrows I went with #1 -
How about This? http://www.ti.com/sc/docs/news/2001/01218.htm
