hotwaterwizard
2,022 -
Everything posted by hotwaterwizard
Noise suppressor for car
hotwaterwizard replied to stuee's topic in Electronic Projects Design/Ideas
I have Been an Audio Tech for 25 years. In my opinion You can not find a wire that is Big enough to replace the Body of the Car. The best possible Ground is the Car Body. Another Hint to Moror noise is to put a Large Ground strap from the Hood to the Frame. The Hood is not Usually Grounded and motor noise escapes from the hood area. -
NICAD Battery charger/reconditioner HELP
hotwaterwizard replied to moltra's topic in Electronic Projects Design/Ideas
How about This? Nicad Charger http://electronicprojects.org/content/view/9/ -
Looking but it is a tuff one!~ STRG6153-SKN SWITCHING REGULATOR
Electronics ballast circuit
hotwaterwizard replied to kyawmin's topic in Electronic Projects Design/Ideas
Check out these Links. http://www.repairfaq.org/sam/samschem.htm#schcfl1 http://www.repairfaq.org/sam/cflamp1.pdf http://www.repairfaq.org/sam/cflamp2.pdf -
Maybe Steven's Projects can help you in the High Voltage Section of this web page. -
LA3161 and LA3221 Datasheets
hotwaterwizard replied to hotwaterwizard's topic in Datasheet/Parts requests
Here is another LA3161 -
Here is the First Datasheet. Still looking for the other one.la3161.pdf
They could Write a book on how to get rid of motor noise! Start with how the wires are Routed. 1) Never run the Audio and Power Wires together. 2) Always use the Body of the Car as the Ground not a Direct Wire to the Negitive post of the Battery. 3) Replace the Capacitors on the Alternator. 4) Look for loose grounds on all components. -
If you need it to latch and un latch it can be modified to do so.
We have the Perfect Thing in our Project Section. Here is the Link. IR Remote Control Project Click Here
Any Electronics Supplier
Will this one work? UCOMP 2.7 http://www.bbk.net.cn/user/revercengineer/downloads/index.php?action=viewall&start=20&sortby=name
Dual LM3886 Bridged Amp.
hotwaterwizard replied to ZomBiE's topic in Electronic Projects Design/Ideas
So what you are saying is db's are like a Hurricane Rating or an Earthquake rating. It has to be Ten times larger to increase a number size. -
Or you can just Pull it out and Make a simple test circuit like they have in the datasheet. KA7812.pdf
compiler for sti55xx ? What is a Compiler? I just look and find. I need a Part Number or an Idea of what I am looking for. ???
Oh man I forgot where I found it! ??? ??? ??? ???
Try this Link. http://www.learn-c.com/schemat.htm
A Schematic is just like a Road Map. It showes you where and how each component is connected. Each comnponent has a symbol that represents it, Some of them have values assigned to them. If you learn what each component is and what it does you can read a Schematic or Circuit Diagram. It takes years to learn Electronics. I will see if I can find a Tutorial for you On-Line. You can start here for now. http://www.electronics-lab.com/articles/basics/theory/index.html
I get this message atleast 10 times a day. application/octet-stream Scan result: Virus "W32.Netsky.P@mm" found. The file attached to this message was infected with a virus that we were unable to clean. You can not download this attachment. Note: Not all viruses can be cleaned. Please contact the message sender and request that they send you a virus-free version of this attachment.
What formula are you using to figure the db difference between 30 watts and 50 watts. I figure that 50 watts PEAK is about 35 watts RMS. So 50 watts RMS would be about 70 watts PEAK. Now lets do the same with 30 watts RMS. 30 watts RMS is about 42 watts PEAK. So if we look at RMS we have a 20 watt Gain and PEAK is a 28 watt gain. So there is a sliding scale to this mess as I figure it. Now Take 30 x .666 and you get about 50 Watts. That is about a 2/3 power gain. ???I just confused myself. ??? How do you figure such a small power gain. -
If the speaker is not in a box that was designed for the specs of the speaker it will not produce optimum sound or decibels. If you just buy a box off of the shelf and speakers off of the shelf they probably don't match. You need someone to do a test on the box to see what frequency it is tuned to. Also you need the tru specs of the speakers. The VAS QTS and Free Air Resonance among other specs. Then Use The Theal-Small Theroy to figure out the box. Also you need to find out if it is a Long throw or a Short Throw Cone. That will determine if the box needs to me a Ported or Air Suspension Box. It gets Real Technical Real Quick! They have Box Calculators Online For all of the Figuring if your math skills are not that good. The Speaker Box is just as Important as the Amplifier when it comes to sound reproduction. ??? -
Schematic/Service manual for SONY model HCD-RV7
hotwaterwizard replied to a topic in Service Manuals
No I just found it after many hours of searching. I am still looking for a free one. -
Oh No my secret source is out! :o
I think there is alot of difference between 30 watts and 50 watts. That is almost double! You can tell the difference between 5 watts and 20 watts so you can hear a big difference between 30 and 50 watts. The distortion of the amp is not the only concern when Bridging amps. They tend to run hotter as well. So the life expectancy of the IC will be Half of an Amp that has not been bridged. -
sine wave generator
hotwaterwizard replied to blacksheep's topic in Electronic Projects Design/Ideas
This Datasheet Explains how to do it on page 9! 555.pdf
