hotwaterwizard
2,022 -
Posts posted by hotwaterwizard
where did you find it.
I have looked almost everywhere. -
I don't see a 161 in this circuit.
Here is another one.
Need more info??? ???
Transistor, IC Diode, Capacitor, Resistor ?????????
I have been looking for it faithfully and have not found it yet.
I Need a 12v version of this.
Usually a varible speed Drill running real slow works well if you mount it in a vice. Run a screw and nut thru the core and put it in the drill. A Lathe works even better.
If we could figure out a way to use a button to increase voltage every time you push it and have a capacitor discharge timer to decrease the voltage slowly unless the button was pushed again we could use a Bargraph Display Driver like the LM3914 ,5 or 6 to do the job. Look at the Datasheet for more Ideas.
http://www.national.com/ds/LM/LM3914.pdf
http://www.national.com/ds/LM/LM3915.pdf
http://www.national.com/ds/LM/LM3916.pdf -
Have you tried Emailing the Author?
http://www.compulink.co.uk/~lasertag/lasertag.htm#diy -
Here are some other circuits to look at.
http://www.lasertag.de/index.php3?i=tech
http://homepage.ntlworld.com/sparta/lcbasic.pdf
http://www.armory.com/~spcecdt/history/ModDescription.html
http://www.myownlittleworld.org.uk/fiat-lux/technical_overview.htm
http://www.1sourcelasertag.com/blank?pageid=9&catstart=0&prodstart=0
http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/s2002/cmp28/hard.html -
Look at these links.
led counters
The Last circuit is closest.
If you use a switch debouncer circuit instead of the timer it will count up when you push the button . Use a delayed on timer with a reset triggered by the same debouncer for the down sequence then you will have your circuit. The only problem is resetting the whole circuit. I think you can just turn off the power to reset the sequence. ???
http://a402.phys.psu.edu/402/Exp/E8/E8.html
http://www.interq.or.jp/japan/se-inoue/e_ckt14.htm
http://www.geocities.com/lemagicien_2000/elecpage/bounlite/bounlight.html -
Here is one from another post in the Circuit Request Section.
IR3To7 is a Preamp.
CLICK HERE TAG GUN pdf
It is not a Datasheet but it is helpful. -
Manufactures would be helpful. Sharp Toshiba?
Ohhh Ahhh
I like it
I Love it
I want Some more of it!
I see it opened. I merged the Two as well.
Well I found a bunch of them at the website. I can Email them or you can go there and download them yourself.
http://www.liteon.com.tw/databook/default.htm
To navigate to the datasheets on the site :
Look to the left side Box Click on LED Display
Then Click on Dot Matrix
Then Click on one of the blue Index Arrows
I went with #1
ZP 1311 G M detector
in Datasheet/Parts requests
Posted
I found Data for a cross referance part#
LND,INC CENTRONICS MULLARD TGM DETECTORS
71412 ZP1311 MX189 N116-1SE / C1312
ZP1311 GM detector
http://www.lndinc.com/crosref.htm
http://www.lndinc.com/gm/energy/71412.htm
