hotwaterwizard
2,022 -
Posts posted by hotwaterwizard
Should I make another one? Maybe Dc motor with a wireless Remote control?
Since there is no way to reply to the original post I started this Thread.
My favorite Logic is the Inverter which is not listed in the poll. It is the most useful to me. -
Explain more.
Are you trying to get Bianary numbers?
Are you trying to get Decimal numbers?
Are you trying to get Bianary Coded Decimal?
A Number Display on a read out?
Simple Led output?
How many numbers Displayed at the same time?
Be more specific. -
Maybe if you gave more info on the motor and how it is wired ect it would help us to help you.
Too bad your Email is hidden i could hav emailed you the schematic.
Why would someone hide their Email Address? -
There is one good thing about the older computers. They don't get as many viruses and they are less complicated.
I took the words in ( ) and did a web search and all kinds of things poped up Try http://www.google.com
This is a package outline for SOT-23 package
http://www.maxim-ic.com/cgi-bin/packages?pkg=6%2FSOT23&Type=Max
LF = NPN if my German is correct check here!
http://www.fed.de/mailarchive/fed-forum/2002-01/3032.html
It is Translated as:
Honoured colleagues,
I look for the type names and the manufacturer of two bipolar
transistors in the SOT-23-Gehaeuse. The construction unit codes read:
"MF" on a PNP transistor "LF" on a NPN transistor
The Pinning is the equivalent BC848/858. Both transistors are from the same manufacturer, since the
construction unit surface and the stempeldruck are perfectly
identical.
Who can help me here? Thank you in advance for each support.
With kind regards
Now here is the Datasheet for the transistor he mentioned.
http://www.semiconductors.philips.com/acrobat/datasheets/BC846_BC847_BC848_5.pdf -
Try this site.
http://servis-manual.com/ -
It has a 1 1/2 hp Reversable AC Motor. The original Motor burned out so I upgraded to a larger motor that is used on electric gate openers. It Runs on 120vac.
It started out looking like this one. I don't have it anymore so I can't show an actual pictures. I had to add a third wheel in the back so it could stand up by it's self. -
I found both of those too It just Gets me that I can find All of these Exact Datasheets for Everyone else but, I can't get the exact one for a simple Transistor for myself. Man it buggs me bad!!!
I started out here and got confused after that.
http://www.vmarsmanuals.co.uk/newsletter_articles/62set_converter.htm -
I believe the D in the part number stands for Darlington and this does not look like a Darlington replacement.
The circuit takes the Ground and switches it on and off alrernately.
This is a Transistor D2065 [M] printed on it which is Matsushita which is now Panasonic.
I figure it is a 2SD2065 NPN Transistor.
It is in a Kenwood KAC-624 Carstereo Amplifier.
There are 4 of them in the Audio Output Stage of the Amplifier.
What is curious about this Amplifier is all output transistors are the same not compliment pairs . The Transistor Gets Hot and shuts down and one or more of these transistors are bad. I need a Datasheet for this so I can see if any of the Transistors I currently have will work in place of this Obsolete Transistor. -
Check out this Website for another Idea!
http://www.ee.vill.edu/ion/index.html -
If you look at thr datasheet it tells you what they printed on the surface of the chip.
The Closest i could find is this Datasheet.
Steper motor Links
http://www.sscnet.ucla.edu/geog/gessler/topics/steppers.htm
http://www.doc.ic.ac.uk/~ih/doc/stepper/control2/connect.html
http://www.eio.com/stepindx.htm
http://www.seattlerobotics.org/encoder/may98/steppers.html
http://members.tripod.com/~schematics/stepper2.htm
http://www.cs.uiowa.edu/~jones/step/circuits.html#practbi
http://www.u-net.com/ph/mas/projects/scotch/motor.htm
Bipolar Tutorial
http://209.41.165.153/stepper/Tutorials/BiTutor.html
Unipolar Tutorial
http://209.41.165.153/stepper/Tutorials/UniTutor.htm
temperature controller in the hatchery
Posted
This is a Low tech solution. Run the water into a clear plastic covered pond and let it stand for a while. The sun will warm it up. Then use a temperature controller to monitor the water and release the colder water while introducing the warmer water untill the desired temperature is aquired.
