hotwaterwizard
2,022 -
Calendar
Posts posted by hotwaterwizard
If you look at thr datasheet it tells you what they printed on the surface of the chip.
The Closest i could find is this Datasheet.
Steper motor Links
http://www.sscnet.ucla.edu/geog/gessler/topics/steppers.htm
http://www.doc.ic.ac.uk/~ih/doc/stepper/control2/connect.html
http://www.eio.com/stepindx.htm
http://www.seattlerobotics.org/encoder/may98/steppers.html
http://members.tripod.com/~schematics/stepper2.htm
http://www.cs.uiowa.edu/~jones/step/circuits.html#practbi
http://www.u-net.com/ph/mas/projects/scotch/motor.htm
Bipolar Tutorial
http://209.41.165.153/stepper/Tutorials/BiTutor.html
Unipolar Tutorial
http://209.41.165.153/stepper/Tutorials/UniTutor.htm -
Found a Cool high voltage site.
http://dave.golfbuddys.com/hvguy/tx4/ionwind/sstc2.html -
Why not use a 556 Dual Timer with seperate circuits on each timer?
http://members.shaw.ca/pferlow/desulfator.htm
http://www.talkingelectronics.com/FreeProjects/555/555-P2.html -
Having a hard time with it. But, I have found alot of links to Stepper motor Tutorials ect. If you want the list let me know.
Here is the second Datasheet
Here is the first Datasheet.
Does your TV have Audio output RCA Jacks in the back?
Does your Player?
If so all you need is a Stereo or Amplifier with input Jacks.
The TV has a limited amount of audio so you need an extra Amplifier to hook more speakers up.
I am an Audio Tech as well as a Pressure Washer Tech.
Believe me, any other way you will burn out the amplifier in the TV and you won't have any sound at all! -
Is this it?
C10 = ECG113A = DS-17 = DS-131
This Diode has 3 pins and resembles a transistor
G10 = 1N4007 = 1 amp Diode DO15 Case Plastic Looks like a standard Diode -
Here is all I could find so far.
R34B16B
General-Purpose Silicon Rectifier Manufacture IR 11 Available
http://www.cmbcomponents.com/ -
Check out page 26 on this one!
http://earthlcd.com/zlcd/downloads/lm24014w.pdf -
Is this the Machine you are working on?
Here is more info.
Frac-100. Made by Pharmacia, Uppsala, Sweden
Parts
http://www.sci-bay.com/partspages/lkb_parts-1.html
http://www.sci-bay.com/partspages/lkb_parts-2.html
Authorized Repair Center
http://www.sci-bay.com/index.html -
Found More Info.
Radioshack 1400 Laptop Parts list
http://support.radioshack.com/support_computer/doc30/30549.htm
To order parts call 1-800-843-7422 or visit your local RadioShack store.
Reference # Cat.No. Description NP Part #
TLX-XD1-8 10878577 IC,T7778A LCD CONT MX1625
10878577 100P FLAT PAK MX1625
TLX-YD1-3 10878585 IC,T7900 LCD CONT MX1626
10878585 92P FLAT PAK MX1626
http://support.radioshack.com/support_computer/doc30/30547.htm[ -
here is one for sale on ebay.
http://www.summitcellularcenter.com/SAD1024-BUCKET-BRIGADE-DELAY-IC-NEW-RETICON,i3714117096,c41415.html
Or you can Buy one here!
http://www.smallbearelec.com/Ordering/Stocklist.htm -
This will help you for sure!
http://www.geofex.com/sad1024.htm
http://www.du.edu/~etuttle/electron/elect39.htm
Datasheet Attached. -
It appears to be a Mono IC chip. Sometimes TA and KIA are interchangable.
I am not giving up on it until I get all of the info or until I get to this Link.
http://www.datamath.net/ -
Do you know the manufacture of the Kit? Maybe the Kit #
BAT29 Schottky Diode
Equivelent 1N5390
SGS Thompson
Purchase
http://www.danssmallpartsandkits.net/
Datasheet
http://www.xinsemi.com/english/up/upload/BAT29.pdf -
Here is something but I don't know what it is.
http://www.technochips.co.jp/freeprog/sanyo_lc78636/lc78636.zip -
I'm having a real hard time with these!
Here is what I have so far. These only mention your chips but, it is something.
http://www.eio.com/lcd.htm
http://forum.microchip.com/tm.asp?m=29114
http://www.mpja.com/download/14619opap.pdf -
I assume it is out of a car stereo. The number reads like a Toshiba Chip. What brand of stereo is it out of and model #
English Translation..
in General
Posted
Here are some links that may help!
http://translate.google.com/translate_t
http://www.tranexp.com:2000/InterTran%20
http://world.altavista.com
http://www.faganfinder.com/translate
What Language is it!
I think it is Polish
