hotwaterwizard
2,022 -
Calendar
Everything posted by hotwaterwizard
search results Type CO-18-R JEC-174A Rating 2A 50Hz Range 0.5-2.5A Style PG060 ICS 0.1/1.0 A RATED VA 30VA SER 81577 DATA 1982 JEC-2510 Overload Relay JEC-2510 Overcurrent relay (old JEC-174A) www.chinait.net/xinghao.asp?id=25145 http://www.ca800.com/product/html/2007-1-1/p19401.html http://fonlee.fonlee.com.tw/Proc/O/omron/pdf/R/K2CG.pdf http://fonlee.fonlee.com.tw/Proc/O/omron/pdf/R/K2ZC.pdf
Post a Picture
Found this http://www.mitsubishielectric.co.jp/haisei/01sei/data/data03sei_siryou/ms/ctlg/02015b/catalog/main_04.htm
Yahoo!! I found it! Toshiba TA75072 Here is where I found the Cross Referance http://focus.ti.com/pdfs/logic/stdlinearcross.pdf TA75072FN Datasheet attached
Thanks I will keep an eye on it.
Schematic using TL072S http://experimentalistsanonymous.com/diy/Schematics/Delay%20Echo%20and%20Samplers/Danelectro%20PBJ%20DJ-17.PDF NJM2082 Datasheet http://www.ortodoxism.ro/datasheets/newjapanradio/ae04023.pdf nte1529_SK7804.pdf
I have 2 Datasheets for this IC
Where does it state Silver Coating on this switch? Where does it state the Voltage or Current Rating of the switch?
They are out there. Search Results ZN416E http://www.oselectronics.com/ose_p81.htm http://www.hkinventory.com/public/OfferInventResult.asp?Order=1&pnums=ZN416E&crit1=&crit2=&category=&product=&keywords=&words=3&country=&postdate=&brand=&crit3=&crit4=0&datecode= http://eshop.bg/eshop3/index.php?url=/eshop3/phps/sitemap_mostviewed.php?start=32 http://www.startronic.se/lista.htm Other Data http://www.jaycar.com.au/images_uploaded/ZN414484.PDF http://www.mikroe.com/en/books/rrbook/chapter3/chapter3h.htm http://www.arar93.dsl.pipex.com/mds975/Content/trfradios.html
Joystick Toggle Switches You found the right page but look deeper and you find this. Joystick Toggle Switches Two Axis http://www.machinecomp.com/js2ax.htm
52" RCA big screen - no power Service Manual Needed
hotwaterwizard replied to hotwaterwizard's topic in Service Manuals
service Dump Part 5 and 6 of 6 -
service Dump Part 3 and 4 of 6 -
Topic: 52" RCA big screen - no power Service Manual Needed Belli on ShareFX Posted a service Dump for me. Here is Part 1 and 2 of 6 -
hotwaterwizard posted a topic in Service Manuals
RCA 52" big screen built Nov 2001 Svc# D52120YX1 Model# D52120 Chassis# CTC211A Need a Service Manual -
Power Acoustik PA2120 Their Website Is of no help. http://www.poweracoustik.com/pa2006/ Why Bother the amp is only $49.95 Acoustik PA2120. 120 Watts Max. 2 Channels. Full MOSFET Power Supply. 3-Way Protection. Variable High/Low Pass.
There are hundreds of them just search with Nixie Tube. Nixie Tubes Search results http://www.sphere.bc.ca/test/nixies.html http://www.best-price.com/procSystem,showProductSearchByUserSearch,,0,nixie%20tubes.html?gclid=CMSnwqWO6okCFSNQYwod4kG1KQ http://search.ebay.com/nixie-tubes_W0QQfnuZ1QQfsooZ1QQfsopZ3QQxpufuZx http://nixietube.nixieclock-tube.com/start.shtml http://www.tubehobby.com/store.php?cat=2 http://www.elexs.com/ http://www.ledsales.com.au/cart.php?target=product&product_id=74&category_id=32 other info on Nixie Tubes http://www.g3ynh.info/digrdout/nixie.html http://www.decodesystems.com/nixie.html http://www.the-planet.org/nixie.html http://www.nixie.tube-tester.com/ http://groups.yahoo.com/group/NEONIXIE-L/
The website does not list that AMP Are you sure
XTAL OSC 4 PIN Oscillator Ebay has the A version Click Here Ebay Item This is the best I could do on a Datasheet http://www.allproducts.com/manufacture3/usi/12_print.html Universal Scientific Industrial Co., Ltd Circuitry UT6 Frequency range TTL Stability 1.5~125MHz Operating temperature 25, 50, 100ppm 0~70 Celsius
Nice Amps they sound great when working. I will see if I can find anything on this amp. It does not Appear on the website as a valid number.
Why use Opamp? http://www.qsl.net/vu2upx/Projects/40apsu.htm
"1525 analog compass" Datasheet http://www.jelu.se/shop/pdf/sensor%20information.pdf Pinout Datasheet http://www.jelu.se/shop/pdf/dinsmore%20r1655%20sensor.pdf Product Page http://www.jelu.se/shop/product_info.php?products_id=137&osCsid=b38cf937c8f44735345dcfd3ef3194a8
Here is the Pinout from the Datasheet Above.
There is one on Ebay right now! Ambit T15I003.01 LCD Monitor Inverter Ebay Item number: 120065905044 http://cgi.ebay.com/Ambit-T15I003-01-LCD-Monitor-Inverter_W0QQitemZ120065905044QQcmdZViewItem
This one is tuff all I can find so far is Panasonic is the manufacture.
