hotwaterwizard
2,022 -
Posts posted by hotwaterwizard
search results
Type CO-18-R JEC-174A
Rating 2A 50Hz
Range 0.5-2.5A Style PG060
ICS 0.1/1.0 A
RATED VA 30VA
SER 81577 DATA 1982
JEC-2510 Overload Relay
JEC-2510 Overcurrent relay (old JEC-174A)
www.chinait.net/xinghao.asp?id=25145
http://www.ca800.com/product/html/2007-1-1/p19401.html
http://fonlee.fonlee.com.tw/Proc/O/omron/pdf/R/K2CG.pdf
http://fonlee.fonlee.com.tw/Proc/O/omron/pdf/R/K2ZC.pdf -
Post a Picture
Found this
http://www.mitsubishielectric.co.jp/haisei/01sei/data/data03sei_siryou/ms/ctlg/02015b/catalog/main_04.htm -
Yahoo!! I found it!
Toshiba TA75072
Here is where I found the Cross Referance
http://focus.ti.com/pdfs/logic/stdlinearcross.pdf
TA75072FN Datasheet attached -
Thanks I will keep an eye on it.
Schematic using TL072S
http://experimentalistsanonymous.com/diy/Schematics/Delay%20Echo%20and%20Samplers/Danelectro%20PBJ%20DJ-17.PDF
NJM2082 Datasheet
http://www.ortodoxism.ro/datasheets/newjapanradio/ae04023.pdf -
I have 2 Datasheets for this IC
Where does it state Silver Coating on this switch?
Where does it state the Voltage or Current Rating of the switch? -
They are out there. Search Results
ZN416E
http://www.oselectronics.com/ose_p81.htm
http://www.hkinventory.com/public/OfferInventResult.asp?Order=1&pnums=ZN416E&crit1=&crit2=&category=&product=&keywords=&words=3&country=&postdate=&brand=&crit3=&crit4=0&datecode=
http://eshop.bg/eshop3/index.php?url=/eshop3/phps/sitemap_mostviewed.php?start=32
http://www.startronic.se/lista.htm
Other Data
http://www.jaycar.com.au/images_uploaded/ZN414484.PDF
http://www.mikroe.com/en/books/rrbook/chapter3/chapter3h.htm
http://www.arar93.dsl.pipex.com/mds975/Content/trfradios.html -
Joystick Toggle Switches
You found the right page but look deeper and you find this.
Joystick Toggle Switches Two Axis
http://www.machinecomp.com/js2ax.htm -
service Dump Part 5 and 6 of 6
service Dump Part 3 and 4 of 6
Topic: 52" RCA big screen - no power Service Manual Needed
Belli on ShareFX Posted a service Dump for me. Here is Part 1 and 2 of 6 -
RCA 52" big screen built Nov 2001
Svc# D52120YX1
Model# D52120
Chassis# CTC211A
Need a Service Manual -
Power Acoustik PA2120
Their Website Is of no help.
http://www.poweracoustik.com/pa2006/
Why Bother the amp is only $49.95
Acoustik PA2120. 120 Watts Max. 2 Channels.
Full MOSFET Power Supply.
3-Way Protection.
Variable High/Low Pass. -
There are hundreds of them just search with Nixie Tube.
Nixie Tubes Search results
http://www.sphere.bc.ca/test/nixies.html
http://www.best-price.com/procSystem,showProductSearchByUserSearch,,0,nixie%20tubes.html?gclid=CMSnwqWO6okCFSNQYwod4kG1KQ
http://search.ebay.com/nixie-tubes_W0QQfnuZ1QQfsooZ1QQfsopZ3QQxpufuZx
http://nixietube.nixieclock-tube.com/start.shtml
http://www.tubehobby.com/store.php?cat=2
http://www.elexs.com/
http://www.ledsales.com.au/cart.php?target=product&product_id=74&category_id=32
other info on Nixie Tubes
http://www.g3ynh.info/digrdout/nixie.html
http://www.decodesystems.com/nixie.html
http://www.the-planet.org/nixie.html
http://www.nixie.tube-tester.com/
http://groups.yahoo.com/group/NEONIXIE-L/ -
The website does not list that AMP
Are you sure -
XTAL OSC 4 PIN
Oscillator
Ebay has the A version
Click Here Ebay Item
This is the best I could do on a Datasheet
http://www.allproducts.com/manufacture3/usi/12_print.html
Universal Scientific Industrial Co., Ltd
Circuitry UT6 Frequency range TTL Stability 1.5~125MHz Operating temperature 25, 50, 100ppm 0~70 Celsius -
Nice Amps they sound great when working. I will see if I can find anything on this amp.
It does not Appear on the website as a valid number. -
Why use Opamp?
http://www.qsl.net/vu2upx/Projects/40apsu.htm -
"1525 analog compass"
Datasheet
http://www.jelu.se/shop/pdf/sensor%20information.pdf
Pinout Datasheet
http://www.jelu.se/shop/pdf/dinsmore%20r1655%20sensor.pdf
Product Page
http://www.jelu.se/shop/product_info.php?products_id=137&osCsid=b38cf937c8f44735345dcfd3ef3194a8 -
There is one on Ebay right now!
Ambit T15I003.01 LCD Monitor Inverter Ebay Item number: 120065905044
http://cgi.ebay.com/Ambit-T15I003-01-LCD-Monitor-Inverter_W0QQitemZ120065905044QQcmdZViewItem -
An Ultrasonic Cleaner--Schematic
Posted
Page 39 is missing
