One last question.... ;) Can I power this with an "N" cell? I know that N cells are 1.5V each, but I wanted to make sure that they can be used in this project. Do you think that a car remote battery could be used as well? Those cells are 12V though. Could they be utilitlized if resistors were added, or something? I can easily incorporate the smaller cells into the structure, as the prop is constructed virtually in CAD, and then a master will be constructed via stereolithography. The big issue that I have as a costume/prop designer is that things, at times, need to be durable, and compact. The AA cells are good, but do not fit the housing that was approved by the studio designer. Also, because of the fight scenes, the fight coordinators and the actors all agreed that it would be better to have the electronics compact as possible, rather than have power leads connect from a belt to device. On a cooler note, I did find some "micro" audio and linear potentiometers that worked fabulously with the circuit design! I can make adjustments with a small phillips screwdriver for speed and brightness! Thank you so much for all the help you given me so far! It's saved me from many a headache, and saved my hairline from being ripped out! :D - frank
