1,698 -
Everything posted by steven
i biult the amplified ear to but it dident work so i changed 2 of the caps to electros and did a bypass job and it worked but i got some feed back but if tou want something that will do ok look at the parabolic mike circuit and electret mike preamplifier somewhere in the forums , well ill post the one im refering to here it dose ok in amplifieing sounds to like the amplified ear would but this ones easyer to biuld
thankyou audio guru ive got another one to biuld yet so it will be my third one . this one i built for a mate
:)heres the latest pictures with the framework completed and most of the wireing all done
Boost converter capacitor charger
steven replied to MrHeckles's topic in Electronic Projects Design/Ideas
well at least someone like to charge up hv capacitors . i cant really give you any coment on the circuit unlless i biuld it first but ic 2 im not familiar with but if you like some great ideas look at my high voltage pphoto flash capacitor charger and hand powerd photo flash capacitor charger in the high voltage stuff section and allso you will find some neat looking ones in the topic by bakr chargeing of capacitor. as ive uploade some hard to get circuits there and includes the hv cap chargeing for the coil gun and veichle electrification circuits to and others to -
here is another high voltage photo flash capacitor charger under construction useing another type of flyback transformer , now this one dosent have a biult in high voltage trippler iether and i used the same components as i did with the first one now as soon as this one is completed well the panel and framework anyhow ill test it out .
:)why buy project boxes when you can make your own to any size you like , from pvc water pipes and plastic corner moulding look in the high voltage stuff section under homemade circuit boxes or whatever ive got it under youll notice that nearly every circuit box in my postings there are made from pvc
look through the high voltage stuff section
:)dont worry about t1 if you biulfing this stun gun there are alternatives like a flyback driver circuit that not only powers flyback transormers but any transformer in reverse mode this will give you some good arcs to look at the topic hand powerd generator i used 2x 6kv ceramics to make a mini marx generator and this alone would be an ideal adition as it put out fat arcs when powerd up from the hand powerd generater
:)hello audio guru ive read all the info on the effects and use of the scalar beamer on the net and there was some who said that they felt like they were in a trance like state when they had the scalar beamer on so the first exsperiment i must of been heading in the right direction then, and the scalar beamer was said to preserve food to like iradiating food which would last longer but ive found before on the net that this may very well of been used by extteraterestrials in the so called cattle mutilations to and humen to as ive seen the photos online of it and the effects of the scalar beamer seems to match exactly what it dose in preserveing food and killing bactieria and thus makeing it last longer before decaying so this is intresting and if its by anychance classed as reverse magnetism then an abductee who was abducted by a uf was told by them that there craft is propeld by reverse magnetism so this m ay be intresting to and things seem to be comeing clear about it
:)the one that is allmost finished ,ive allread wound the coil into it
:)here is a picture of what im biulding its not yet finished , the one thats allmost finished out of the 3 i havent taken a picture of it yet but will do as soon as i get a horse shoe exenon flash tube for it
:) has anyone tried biulding or exsperimenting with the bendi scalar beamer . i just like to know what results they got .ive biult one before but i dident follow the instructions by bendi and i got an effect like it put me in a trance like state. and now ive been busy biulding a tripple scalar beamer , useing ceramic magnets that ive collecetd from microwave oven magnetron units , now the wierd effects of these scalar beamers is intresting so when complete ill add all the details here ive nearly completed one out of 3 scalar beamers so far and will even try powering it from the high voltage output of my high voltage circuits like the ignition coil and flyback drivers circuits
Electronic Ignition (Transistor + points)
steven replied to cpcarranza's topic in Electronic Projects Design/Ideas
:) ooh forgot to mention you may want to take a look in the high voltage stuff section to as ive posted lots of stuff there that may be of use to you includeing ignition coil driver circuits that i biult from circuits ive collecetd you may find some ideas to asisst you in there somewhere -
i dont know where it is but it could be there in high voltage circuits im not sure i could still have a printout of it up stairs somewhere in my collection of thousands of circuits its an electronic ignition circuit of some kind that may be usefull to you ill add it to your topic if i can find it again -
i dont have much to say but if you biuld it and it works its good enougth ,i think ive posted some circuits in electronics lab sometime ago that may relate to this in one way or another but i dont remember for sure -
thhe 0.1uf capacitor is a tantulum and i forgot to mark the positive end in the printed circuit i drew up which is a bit rougth ill redo it latter when i actually make the printed circuit board for it
:)here i drew up a simple printed circuit for this second keychain laser power
heres another simple keychain laser circuit i made and added some detailes to it and drew a simple printed circuit for it
nice pictures keep up the good work -
hhey dazza the browns gass thing ive read about seems to do the same thing as my simple exsperiment did where i used diodes for the electrodes in separateing hydrogen and oxygen from water with iodised salt in it . the bubles in my exsperiment go sideways instead up up, for about half way before riseing , has i wonder if brown himself ever had the same effect iether, as i dont remember ever reading of him getting the same as i do ,and the water goes black colour and sludgy like to when i use the diodes for electrodes
well im not gain enougth to look into the laser even from a long distance away but i like to hear more of any of your laser exsperiments i have a 3 leg laser i got from old cd unit but i dont know about these nor how much voltage they run off its like a transistor that has lense window on top and i dont know anything about this one its metal to
Voltage that drives the speakers
steven replied to shaiqbashir's topic in Electronic Projects Design/Ideas
:) this reminds me of one of my photoflash cap charger circuits from the camera i switch it on and charge the cap up then dump the charge right into a small speaker and get a big pop sound and it handles it ok -
:) ill add to that ,mp is a really great and reading his replies etc etc is better than reading a news paper and any comic magazines , we can all lern from him he is a master at it, and electronics lab is great with mp around, this place wouldent be here with out him , i think ,
:) try electrostatic cooling ive herd of this years ago but nevr checked it out and heres one not on the topic but ive herd of an invention that was at an inventors exspo and it produced a cold flame that dossent burn your skin my brother said he saw it years ago.
