Aman bharti
Members
  • Posts
    31
  • Joined
  • Last visited
Posts posted by Aman bharti
  1. When Light fall on LDR in DAY then the Resistance of LDR goes LOW And  at this situation the maximum voltage Dropped With Negative supply (Ground) by cross through LDR and Voltage at the Base of transistor Q1 is Very LOW.  When the Voltage goes to very LOW (Below0.7v) at BASE of Q1 then Transistor not get ON and no Power flows between COLLECTOR and EMITTER. Gate Voltagr of TRIAC is LOW.  Now TRIAC Remain OFF Because It not TRIGGERED.
    At Night Time when no light incident on LDR then the internal Resistance of LDR comes HIGH and Very less amount of Power cross through LDR to ground , then the Voltage At base Terminal of transistor become increase (above 0.7v) and now transistor turn ON and current starts flow between Emitter and COLLECTOR. Therefor the Voltage increasing at GATE of TRIAC BT136. As voltage increase at GATE then TRIAC get Triggered .  After Triac triggerd it Turn on and Passes the Power Supply between terminal 2 to terminal 1 and Bulb Switched On.
    For more sensitivity use 2 LDR with parallel.
    For more detail go to http://www.circuitspedia.com/automatic-light-controlled-bulb-switch-using-without-relay/
    And also go to http://www.circuitspedia.com/category/light-operated-switch-circuit/
  2. DC FAN Motor Speed Controller Regulator Circuit Works ON Principle of Pulse Width Modulation (PWM) technique , By Using This Technique Controlling Of DC Motor
    Speed is very Smoothly And Noise Free. Tested on 12v 1 A DC Motor
    For Full detail with live demo click on http://www.circuitspedia.com/dc-fan-speed-regulator-circuit/
    By This Method Smoothly Controlled The Speed Of DC Motor At Negligible Noise
    BY using This Circuit You can control the speed of DC Fan by tunning the (Potentiometer) volume control variable resistance. These circuits are based on 555 Timer .
  3. High Sensitive Clap Operated Sound controlled ON OFF Switch Project
    This clap operated ON OFF Switch circuit is very sensitive and easily operated upto distance of 5 Meter If condenser MIC is fix into a Special type of Cover to Receiving More Sound From Maximum Distance.
    This Clap/Sound controlled ON OFF Switch circuit consists two ICs , two NPN transistors, One PNP Transistor and some other components.
    The LM358 and 4017 ic is used. LM358 is an opamp-comparator which has two Op-Amp in a single ic chip. This ic is dual operational Amplifier But in this circuit one op-amp is used.
    For Full detail click on link http://www.circuitspedia.com/sensitive-clap-operated-on-off-switch-circuit-without-microcontroller/
