4138 -
Everything posted by ante
Boosting Regulator Current/ATX power supply
ante replied to coder's topic in Electronic Projects Design/Ideas
coder, The battery voltage (12.7V-5V) * 1.3A = 10W of heat, this needs a good heatsink. I hope you are aware that this circuit have no over current protection! I recommend you to make a modification to be safe. Like this: Ante ::) -
Coder, As far as I can see the circuit is OK as you have drawn it. I have to ask: what is your input voltage to this circuit? Ante ::) -
Kevin, I don -
Kevin, The output side of the regulator is monitoring the output voltage and feedback to control the transistor is produced in the BE resistor. Ante ::) -
Kevin, If using very low currents it is possible to use zeners and resistor dividers, but otherwise it is a very "lossy" way to go. You must have some idea of the current needed nA, mA, hundreds of mA or A. And of curse the voltages involved. An interesting thing is if you can use common ground (negative) for all the voltages or not. Ante ::)
Kevin, The transistor is not backwards! Here you can see how the boosting regulator is calculated: Ante ::) -
To All, To minimize the temperature in the power stage it is important to have fast rise and fall times =(nice looking square wave). There are two ways to go with the choice of frequency. One is to calculate the optimal frequency for the motor used, second to use a high frequency like 15
Kevin, A low value resistor tap or a Zener circuit could hardly be an optimal way to go. What voltages and currents do you need and in what kind of environment is the circuit suppose to
Darrin, Have you checked here: http://www.intertechnology.com/Vishay/pdfs/Catalog_500A.pdf Ante ::)
Sasi, I am sorry but I can -
AJB2K3, Thanks for letting us know! Ante ::)
Coder, Is it possible that you have swapped the PNP transistor for a NPN? Ante ::) -
Rhonn, Can this be what you are looking for? http://www.kemo-electronic.de/en/bausaetze/b005/index.htm Ante ::)
Sorry, I believed it was a mistake curse I don
audioguru, Greg asked
;D Greece Are European Champs! ;D Congratulations Greece a well deserved victory! I will not comment on the Swedish team. :-X Ante ::)
Greg, Welcome to this community. I assume you are using an analogue meter since you want a 0
audioguru, Take a look at the power transistor data sheet. The SOA tells me they will cope as they work in pairs it is possible to get 0.1 V @ 5A with a good heatsink. Am I right? Ante ::)
Hi All, I found an article about a Lab power supply. It
audioguru, The first point, only under certain condition it can be true. If the current draw is high and there is a voltage drop the motor looses some of it
suresht, These links will give you a start. http://www.arcelect.com/lightnin.htm http://www.taunton.com/finehomebuilding/pdf/Lightning.pdf http://www.hq.usace.army.mil/ISD/YellowPages/info/lasps.html Ante ::)
How to increase reactance in a coil of few turns?
ante replied to thrival's topic in High Voltage Stuff
Thrival, I am having a hard time interpreting the schematic. Is this the original schematic? I can -
Oh, I forgot :-[ if you don
Rhonn, Don
AJB, If it
