4,138 -
Everything posted by ante
audioguru, My point is there are alternatives to
You are Good John, you are good. If there ever is an expert in finding data sheets, it
Well when I think of it, why does my car only have two headlights? If there were four of them I would have twice the light in the dark! And why is it fitted with a 70liter petrol tank, a 200liter would carry me much longer? What the heck does these car manufacturers think of? But then again, my car works anyway! Irrelevant? Oh yes! Ante ::)
Hi Guys! Maybe it
Kasamiko, I hope to see some screen dumps of the waveforms on this forum soon then! Take care and don
Kasamiko, Yes, I think the SSP2N60B will work for your project. This 600V 2A N-channel is worth a try. Keep us posted on the progress! Good Luck. Ante ::)
Hi, This is not much but TDA9387PS belongs to a family, the (TDA935X/6X/8XPS/N2). Maybe this gives you more possibilities for searching. Ante ::)
Sorry, maybe it
Kasamiko, How you connect it to the soundcard depends on which software you use. Most of them use the line-in for this but even the mic-input is sometimes used. Both channels is used to dual channel scope software. There is also some software for frequency measuring if you just want to count the waves and not look at them ;D which uses the same inputs. Ante ::)
Kasamiko, I see, you have problems getting components at your place. To find a suitable MOSFET for this purpose I would look in an old PC PSU if you can get your hands on one. Or if you want to have a bipolar BUV 90 is a good choice, common in old TV sets. Ante ::)
Kasamiko, When I test relay contacts I measure the voltage across under load, anything more than 0.0 V and you have a problem. Ante ::)
How did the test turn out, (battery direct to the relay)? Ante ::)
Hi, I have a manual for a HM 203-7, it mite be similar in some parts. Ante ::) Hameg-Scope.pdf
Kasamiko, I found some schematics for it! Hope it helps! Ante ::) AIWA-NSX-A555.pdf
Kasamiko, My earlier post http://home.online.no/%7Esondred/Gamle%20sider/attenuator.htm is not using any ADC, it
Kasamiko, Why don
The URL works but there is no update. The circuit and description is the same. Ante ::)
Amen ! ;D Ante ::)
Beats me! Is there some gearing, say 4:1 from the crankshaft to the magneto? Ante ::)
Thanks Mixos, It works perfectly now! Good Work! Ante ::)
Mixos, great work! I used to link with http://electronics-lab.com/forum/index.php but it does not work anymore. I get a 404 on that one. Now I have to use the
Hi baja, What kind of motor is this? A normal one cylinder four stroke fires once for every two revs. And this will calc. (Hz = 0.5 * revs.). Ante ::)
audioguru, These are your own words:
Kasamiko, If it works fine when pluged directly to the wall you must have some resistance in the circuit. Have you measured the voltage before and after your relay? Does it maybe have burned contacts or is it in some way not suitable for this job? Ante ::)
