4,138 -
Everything posted by ante
As with transistors in parallel you can
If you don
Have you tried
16 or 24 Cannel Gang Switch
ante replied to jasonlaronde's topic in Electronic Projects Design/Ideas
Does the high power relays have any extra contacts that could be used to latch? -
Have you grounded the circuit like it shows in the diagram? The
Is a GFCI outlet a good or bad idea for an electronics workbench?
ante replied to Color Bond's topic in Electronics chit chat
Omni, I have never seen any problems with GFCI -
Perfect! This article is an in depths walk through of the 723 internals and the surrounding circuitry!
prevent live and neutral from changing.please help
ante replied to keron's topic in Electronic Projects Design/Ideas
A couple of relays might help. -
All right, Thanks gevv! ;)
UNIVERSAL BATTERY CHARGER/DISCHARGER(PLZ help)
ante replied to alani_gr's topic in Electronics chit chat
What -
Between gates there should be no reason for resistors.
I must have missed that one back in the eighties; I don
This will probably be useful: http://www.personal.dundee.ac.uk/~gathomso/EG2103/pull-up.doc ;)
It should work if the power requirement is low and the frequency stability isn
That
Perhaps 20mA is not enough for a Power LED as requested here!
Well, now everybody knows your personal views!
No smoking needed, the second channel dropped its regulation due to voltage drop. You know they don
You are way of; start reading up on things before you open up! There is NO arcing when the contacts are closing unless a. the voltage is high enough to jump across the contact pair before they are shut or b. the relay is stupidly under-dimensioned for the purpose! What you might se at the closing moment could be a spark NEVER arcing! And you know what you can do with the
Hi keron, The circuit is not complete; here is how I've used the MOC3041 to switch a transformer. http://www.electronics-lab.com/projects/power/036/index.html The mains circuit part of this project should work for any inductive load.
Arcing is NOT caused by switching IN a load! Arcing is caused when opening the relay contacts (switching out a load)!
Hi AG, Not always completely true. I have experienced dual PSU
Are the output connectors switched?
