leo1500
29 -
Everything posted by leo1500
thank you Leo
Can i use thise model EICO 1050 a for dc power supply? It reads AC 105-125v 150w 50-60~ . DC 0-8v or 0-16v continuous 6v-10a or 12v-6a intermit 6v-20a or 12v-12a. Thank you Leo.
To Audioguru , thank you very much for your advice it works very well. Leo
I would like to build a radio noise filter. When i put on my cooling dc fans in the stereo cabinet , the radio makes a heavy static noise . when i shut the fans off it stops. i need help. Thank you Leo
I would like some help with a project. the out put on my A/V receiver plug is120 av at 100 watt .I would like to put in a second power supply through a relay. (IN 120V 100 WATT OUT 120V AT 5 Amps) so when i put the A/V receiver on , the Fan ,sub-woofer and the am antennae signal will work together. Thank you Leo.
I bought a digital mounting thermometer 12 volt,for a riding lawnmower with an air-cooled engine have to put in a zener diode,to control the starting voltage of about 55 voltage for a split-second.The thermometer draws 3mA and maximum voltage 28 volts.How do i install this diode.A diagram would be appreciated. LEO
I'd like to know how to build a small heat gauge,preferably digital,for an air-cooled engine, 12 volt electrical system,on a riding lawn mower. leo1500
How do I test these darlington transistors whether good or not ???? Leo
Iam looking for a sony compact disc player manual . Model #cdp-c27.Thank you. Leo1500.
I built the car battery charger under the (home, projects, automotive) section. source: http://www.aaroncake.net/ The battery charges at 4 amps and then drops to 2 amps but never shuts off. any ideas what I may have connected wronge?
