V8meathead
Content Count
64 -
Calendar
Everything posted by V8meathead
Using Thevenin's theorem on Wheatstone Bridge
V8meathead replied to V8meathead's topic in Theory articles
Ah ha! Thanks, I appreciate it. :D -
What's the correct way to use Thevenin's theorem to find the current going through Rs? I keep getting 5mA and it should be 3.33mA. I can't figure out where my problem is.
Engineering Electromagnetics Solution Manual?
V8meathead replied to shaiqbashir's topic in Electronic Resources
awesome I'll give those a shot. Thanks :) -
Sorry to go off topic here but how do you go about getting solutions manuals for textbooks? Is there an easy way to do it or find them? I always wondered where the hell people got these things from. ??? Like could I get one for my Signals book by John Wiley and Sons publishing? I just feel like the kid who got left out when it comes to these sort of things cause everyone seems to have one but me. :-\ -
Awesome, this is going to save me tons of time. I'm going to need the datasheets for my logic and digital class. Thanks. Bookmarked! 8)
Thansk for your help! I was mainly asking about how they did the current loops for the middle circuit. The main thing I was having trouble with was the defined capacitor polarity in the middle. When I run my loops in a clockwise fasion like the professor I get different equations from that signals book. But I think when you throw them into that matrix I'm pretty sure everything turns out to be alright. The thing that was confusing me is that they ran their loops in 2 different directions for the middle loop, which is why you get 2 different equations. I was just curious as to why you de
Alright 2 of the same circuits. One is from the signals and systems made ridiculously simple book that was posted on here. The other one is from some professors notes I found online. They get two different equations. >:( Which one is correct and why!? How do you figure this thing out, because I am confused as hell. The first picture is from the professor. The second is from the book. They take a KVL equation around an RLC circuit and come up with two different equations. Both assuming the same sign convention. Maybe it's me that's screwed up. ??? Can someone help please!?
Making LEDs turn on at a certain resistance
V8meathead replied to ribrab's topic in Electronic Projects Design/Ideas
wayyy off topic, but where did you get the symbol for ohm? :P Sry I had to ask. -
To begin, my friend was building an 7 seg display counter using a programmable logic chip the other day. He was using a push button to control the pulses going into the PLD. We obviously had a bad bounce problem with the push button, but sometimes we could get it so all the numbers would sequence like they should(1,2,3,4,5..etc) with no jumps. In order to get a clean switch, I tried 2 things. I first tried an ordinary debouncing circuit using a 555 timer, and then when that didn't work right, I tried a one-shot multivibrator using the same 555. What was happening was the numbers would jum
What's a snubber capacitor, and what's it used for?
thanks for the help, this cleared it up. -
Used to stop switching transients right? Can anyone explain this in more detail? Thanks.
Once you find the total current I(p). And you want to find the current going through one of the two resistors. Take... I(R1) = [R2/(R2+R1)]*I(p) or I(R2) = [R1/(R2+R1)]*I(p). These are called a current divider equations.
Well I've searched Google, and wikipedia. I have a pretty good idea of them. But I need some more examples or something. I guess I'm not really picking up on the idea fully. Any of you guys have any information on them that could help me out? Practical stuff or Book stuff. Doesn't matter to me. Thanks. 8)
http://www.maxim-ic.com/appnotes.cfm/appnote_number/815/ln/en What's your take on this? ???
haha audioguru your second to last post cracked me up!
There are also negative resistance Op-Amp circuits. Voltage increases inversely(?) I believe with current. I believe it looks like a negative slope. If you are really interested. I will take the time to verify it for you, just ask.
How did I blow out a leg of a Bridge Rectifier(BR82D)
V8meathead replied to V8meathead's topic in Electronics chit chat
Perfect. Thanks! -
http://www.stacoenergy.com/variable_transformers.htm one of these things. The plug and cord model. -
Thanks for clearin this up I appreciate your help ill try that :D
thanks Ldanielrosa and Alun. :P actually wait a second. I actually didn't use a regular transormer. I used one of those 3 prong, variable voltage transformer things that can supply more current and has higher voltage ratings than a regular function generator.(smaller boxy thing and heavy as hell) I pluged it into the wall and threw together the leads off of that. I thought that current was the case. But your probably right considering my explaination does sound a bit weird. Do they share the same ground then too? the scope and big transformer thingy? I seriously don't know. If you woul
