Muhammad Abu Bakar
145 -
Everything posted by Muhammad Abu Bakar
Local Positioning System (I need some help)
Muhammad Abu Bakar replied to CPW's topic in Electronic Projects Design/Ideas
Hello CPW! My words: Its tooooooo complicated ;D CPW have you considered this idea! If you can go with RF then use the directional antennas in trilateral configuration. The antennas should receive signal from the car and each should try to track it. Hence from the angle positions of the three you can find the distance/position. -
Best of 30 LM3886 Application
Muhammad Abu Bakar replied to gevv's topic in Electronic Projects Design/Ideas
Hello gevv! Thanks a lot for the stuff you are presenting here! You are doing a gret job. Keep it up!!! :D :D ;D Regards -
Hi Ante! I did it with a bipolar one but the motor spined as easily as before.
Hello Smuralisankar ! Just wait a few moments. Luckily this site has got a large number of “thieve”.
Salam Fasih How are you! It seems you have 1to4 mx. I don't know what is your exact need as you havn't told one. Where you are using it. However a 2 bit binary counter connected to select inputs should work. counter have to have a pulse from 555. Flip flops can also be configured as counters. Also I told you about CD4017 which has built in counter+mux. Regards
Aslam O Alaikum Fasieh For avery simple demo you can use cd4017 decade counter IC with 555. Also google, you will find many.
power line communication
Muhammad Abu Bakar replied to prateeksikka's topic in Electronic Projects Design/Ideas
Hello! In PLC the power a high pass filter blocks the high voltage at 50/60 Hz. Normaly 60KHz to 250KHz is the band used for comm. Either AM or FM modulation is used to shift the spectrum. Also have a look on LM565 and LM567 IC datasheets. -
Difference b/w Electrate and Condensor mikes
Muhammad Abu Bakar replied to Muhammad Abu Bakar's topic in Theory articles
Hello AU! Yes, the replacement isn't electret one. But I wanted to experiment for better sensetivity. Then I want to build this amplifier. Can't ther be some compromise on the voltage requiered? Any suggestions, please! -
The thing I am considering cond. mike, I think, also has polarity. red & black wires soldered. Which kind of mik bears highest sensitivity? Thanks for Ans! -
Hello Dear All! I want to know diff b/w an electrate & cond mike. As I replaced elctrate mike in an FM Transmitter Kit with cond, it didn't work. Electrate mike was fulfilling the job successfully earlier. Also which one is more sensetive (If they are diff things)?
Any data about these photosensors
Muhammad Abu Bakar replied to Cyril B.'s topic in Datasheet/Parts requests
Hello Cyril B! Here is the link which shows how to hack mouse sensors. I hope it will be usefullhttp://www.boondog.com/tutorials/mouse/mouseHack.htm#Parts -
Facing problem in inverter Design
Muhammad Abu Bakar replied to snrkarthik's topic in Electronic Projects Design/Ideas
Why not people use bridge circuit to drive the o/p transformer, so that a centre tapped transformer can be avoided. I am interested in technical reasoning. -
Hi Logon! Good to hear about Staigen's good health. Logan do you enjoy dollar free flights then? ??? :D :D
50 by 50 led wall!!! for discotheque
Muhammad Abu Bakar replied to nissangaw's topic in Electronic Projects Design/Ideas
Hello Nissangaw ! I don't have to say much, except 50 X 50 = 2500 LED's, not just 250! ;) -
Yes, you got it right. Acutually I was just about to tell you. :)
Hello AU, Luckily I had oppertutinity to play with 1KVA trafo at my college. I can remeber the load test where we dropped upto near 50% voltage.
Logan I remeber another place where u could c who is doing what at forum? where's that? I think u must know it :)
"SEARCH" Facility of the site
Muhammad Abu Bakar replied to Muhammad Abu Bakar's topic in Feedback/Comments
Thank You Logan! I will change the way I used to locate the things. I just copied the link at a safe place and at another time when tried to find it then.... Now I have the due respect for the "SEARCH" button. -
Oh! :o ;D I had a look this page a long time ago and always wondered where I could refind it. Thanks
Hello nutty boy! Here goes an experiment to measure max output current. 1. Measure o/p voltage or trafo as V1. 2. Put a high wattage low value variable resistance (better use Rheostat) with max resistance. 3. Decrease load resistence untill you get half of V1 (i.e. V1/2) 4. Take rheostat/load out from circuit and measure its resistance, R1 5. V1/R1 is the max current u can have from this trafo. O.K.
I am much annoyed with the search icon here. I think it better to have none. As I failed ever to find an article with search I had to put it here You might prove it by typing in search "The Robot Builder's Bonanza" which is in Elect Resources >> Electronic related E-Books. You will get "No results found".
