kaimdaim
4 -
Everything posted by kaimdaim
Help request about an optimum switching design
kaimdaim replied to kaimdaim's topic in Electronic Projects Design/Ideas
Thanks @HarryA; coincidencely I was searching for single pole 6 position rotary switches today...It looks to be the best option, as you already mentioned. -
These electrodes stack into ground to estimate resistivity and then electrical tomography of the survey area. -
I made my measurement design just depending on the resistivity measuring technique. I can just add a photo of the instrument which I made and now I wanted to develop it in order to decrease the measurement time by a switching design. Another detail is that during the measurement the electrodes are dipolar.For example,in 1-2+3-4 step,3 is negative pole and 4 is the positive pole,and then in the following step 1-2+4-5 the electrode 4 is the negative pole. That's why switching configuration has become a problem for me.I manually plug the jacks of the paired electrodes according to the order,and get the measurements via 2 multimeters; one of them for V,and the other for I.The first pair of electrodes is to measure the I in miniamperes,and the lateral pair is to measure the values in minivolts. https://imggmi.com/full/2020/1/27/66c8c6ad5b4438c5e49d335e15a4751d-full.jpg.html -
I have 9 driven electrodes. I want to read (I) and (V) measurements via these probes. Here is the pairing configuration(Current is measured via the first couple ,and the voltage is measured via the second couple):1-2+3-41-2+4-51-2+5-61-2+6-71-2+7-81-2+8-92-3+4-52-3+5-62-3+6-72-3+7-82-3+8-93-4+5-63-4+6-73-4+7-83-4+8-94-5+6-74-5+7-84-5+8-95-6+7-85-6+8-96-7+8-9As seen,the total number of pairings is 21.So,what kind of switching configuration would be the best,in order to save time utmost for measurement process?I would like to get ideas to achieve an optimum design.
