NastyRhythm
2 -
NastyRhythm's Achievements
Need some help powering motion detector water spray
NastyRhythm replied to NastyRhythm's topic in Power Electronics
Awesome thanks for the help. I have got 3 Samsung 18650 batteries, so was planning to use those, although they are 3.6v so my output would be 10.8v - Do you think that would be ok? I have purchased this 3 cell battery holder 18650 Battery Holder Storage Box Case 1 2 3 4 Cell 18650 DIY Soldering | eBay And also this BMS board 3S 10A Balance Li-ion Lithium LiPo 18650 Battery BMS Protection PCB Board 12.6V | eBay As i already have a separate charger for the batteries, the circuit doesn't need to accept charging, (i plan to remove batteries and recharge when needed), but do i still need the BMS board, if I'm charging batteries separately? From my understanding the board helps maintain the discharge rate of certain cells so they don't go too low -
Hi there, hope someone can help. Ok firstly i am trying to build a water spray system that uses a 12v Solenoid which will be controlled by a PIR module. Here are the parts i have so far; 12v Solenoid: DC 12V 1/2″ Magnetic Electric Solenoid Valve for Water Air Normally Closed | eBay PIR Module: PIR IR Pyroelectric Infrared Module Adjust Relay Output Human Body Sensor 12V XD | eBay Rectifier Diode: 4 off 6A6 Rectifier Diode 6A 6AMP 600V RoHS | eBay +Various housing parts and connections for the hose pipe It is to stop next door neighbours cat from cr@pping on the driveway. So when the module detects motion it will open the solenoid and water will shoot out. I have basically been following a guide on YT, but on the video he is using a 12v power adapter plug, whereas I want to use rechargeable lithium batteries. Any advice on the batteries? Which ones i should use, and also the wiring of the battery pack? Many thanks, im a novice when it comes to this sort of thing hence following the guide on YT, so any help or advice would be great
