15 -
Calendar
Everything posted by M Salman Sarwar Khan
https://www.pcbway.com/project/shareproject/LM324_Battery_Indicator.html this is conducting on LM32 to control the controller it will help you in this regard. Complete instrumentation of LM32 is given to control the fan.
- 2 replies
- fan
- cooling fan
(and 7 more)
Tagged with:
the USB tester
M Salman Sarwar Khan replied to Sekemiat KE's topic in Electronic Projects Design/Ideas
This link is a TTL to USB converter and it works fine but first please explain what's your product? after knowing the details, I could give you a better response/solution -
Advice Please On this amp design
M Salman Sarwar Khan replied to john121's topic in Electronic Projects Design/Ideas
Decompensated operational amplifiers have improved noise, slew rate, harmonic distortion, etc., but required external compensation for stable operation. This report shows how to compensate such an amplifier and achieve the performance enhancement it provides in a unity-gain configuration. -
School Project Help.
M Salman Sarwar Khan replied to ozgunoral's topic in Electronic Projects Design/Ideas
the broadest choice of op amps in the industry, delivering unmatched quality, robustness, and performance to enable optimized solutions in automotive, industrial, consumer, and healthcare markets. check this article https://www.analog.com/en/products/amplifiers/operational-amplifiers.html -
A motor powered by water.
M Salman Sarwar Khan replied to Stephen Dickens's topic in Power Electronics
this article is also interesting motor power by water, check this out https://www.lowtechmagazine.com/2013/09/power-from-the-tap-water-motors.html- 2 replies
- alternative energy
- free energy
(and 2 more)
Tagged with:
How to check CPU Serial Number of pcDuino1/2/3
M Salman Sarwar Khan replied to Linksprite-Yuki's topic in Service Manuals
thanks fro sharing.. it definitly help me. -
thankyou for sharing this much information about semiconductor. i have exam tomorrow it will definitly helps me
thank you it is very help full.
https://www.pcbway.com/project/shareproject/inverter_12V_To_220V__using_TL494.html this project clearly show the purpose of 103 tripot and use of 2n222a . hope this will help you finding your question.
Newbie Circuit Designer
M Salman Sarwar Khan replied to Yoda Man's topic in Electronic Projects Design/Ideas
LTspcie, pspicem Multisim, protius, these are the best simulation software. you can use any of them -
there is no specific information given in the question, what do you want to find or what is given. you only give RLC values which is very useful in find some circuit parameter but havent specified what need to find here?
Mosfet operate in different region to perform specific operation, but to develop mosfet as an amplifier it should operate in enhancement mode. https://www.electronics-tutorials.ws/amplifier/mosfet-amplifier.html#:~:text=MOSFET Amplifier uses a metal,field effect transistors%2C or JFET's.
The unit of power is not amps. you should use Watt. as far as I understand you question, you want a 100 watt supply with volts vary from 1 to 220 volts. The output power we can calculate by using formula P=VI so you can vary current and volt to get desire output power. To vary current and Voltage you can use transformer.
