Sekemiat KE
21 -
Everything posted by Sekemiat KE
On this issue. As a USB manufacturer I want something that can be used to test if my USB is working without altering if and before sending them to the market... So advice me
to understand the standard measurement for the breadboard check here Other Breadboard Sizes | Breadboards for Beginners | Adafruit Learning System
what exactly do you want? the name of the component or the datasheet of the components
you have just given the numerical data without being specific on what we need to do ... please post the question
check this one here and maybe it can help you Motorola R2600 Service Manual - Free PDF File Sharing (juweliervisser.com)
for the manuals check through this link Panasonic SC-DM3 manuals (manualsdump.com)
hello check Thomson TV circuit board diagrams, schematics, PDF service manuals - Smart TV service manuals, repair, circuit diagrams, schematics (smarttvmanuals.net) and you will know a lot of things about the Thompsons tv boards
In my fridge I have a fluorescent tube that helps in the lighting of the fridge. I have problem with the kind of the operations am getting from the lighting system. I have checked all the part and i have realized that they are working well except for the choke which has a problem. I even dont know how i test the functionality of the choke although from observation it has some black smoke. Help me out to see the solution.
hello everybody. Am a USB manufacturer and I have had many complains from the end users of my USB product where by after sales I have gotten several information that the USB is not working, I really want to know how i can over come such challenges as for now my company reputation might go down. I want to know how i can test the end product to ensure its functionality without injecting into the phones. I have come across this type of tester ATtiny85 USB Tester - Share Project - PCBWay and am not sure if it is the best. Could any of you have adifferent idea about what am thinking of doing?
first have a look at the information about transformers here Introduction to Transformer - The Engineering Projects. in this link you will learn a lot about how transformers work and how you will select the best transformer to replae the one that you have. Good lack
can you check the datasheet in this link FQB60N03L Datasheet(PDF) - Fairchild Semiconductor (alldatasheet.com) it will help you so much
from my end i can realize that this is just a manufacturers part number and not standard part numbers
Transistor Substitute.
Sekemiat KE replied to electronics_shamim's topic in Datasheet/Parts requests
hello 2SD613 NPN replacement is BD243C 2SD633 replacement BD649 2SD600 has replacement BD139 2SB631 has replacement BD140 -
Schematic / Datasheet for LY6806 device.
Sekemiat KE replied to vidalv's topic in Datasheet/Parts requests
Hello! the best way is you draw the circuit and simulate it by yourself. That is the only way coz you will even be able to select your own components and feed the right foot prints. -
The best way is before using a long time disused electronic device you need to change the electrolytic capacitors. It is good to avoid risks accompanied with using a faulty capacitor.
My robot shows an error on the left wheel
Sekemiat KE replied to Holy Hathaway's topic in Electronic Projects Design/Ideas
Can you share some photos of the board so that i can try to understand what you really want. -
Am sorry that am seeing this in 2022. Hope you got the solution. If you never got one let me know so that i can give you a complete solution that I did sometime back.
Hey! I think we have so many open source software that can help you learn about circuits design. The best thing is first to get some relevant knowledge on simple electronic components and their functions eg resistors, capacitors, diodes, transistors, inductors and transformers. If you get information about this you will be almost there and you can start designing your first simple circuit.
