crystallin
Members
  • Posts
    2
  • Joined
  • Last visited
Everything posted by crystallin
  1. What is LDR?? What is LDR (Light Dependent Resistor) as the name states is a special type of resistor that works on the photoconductivity principle means that resistance changes according to the intensity of light. Its resistance decreases with an increase in the intensity of light. It is often used as a light sensor, light meter, Automatic street light, and in areas where we need to have light sensitivity. It is also called a Light Sensor. LDR are usually available in 5mm, 8mm, 12mm, and 25mm dimensions. LED Emergency Light Circuit with LDR (Light Dependent Resistor) LED emergency lights energize when lighting is insufficient or mains power cuts. Earlier, fluorescent lights were used to build such circuits. But it turns out that the use of LEDs can provide adequate lighting for a longer period of time before the battery completely dies. In this project, we will build a simple LED emergency light circuit using LDR. Photoresistors or photoresistors are components that are sensitive to light. It is basically a photocell that works on the principle of light guiding. This passive component is basically a resistor whose resistance value decreases as the light intensity decreases. It's not uncommon for an LDR or photoresistor to have a resistance value of a few megaohms in the dark, then drop to a few hundred ohms in bright light. Hardware Components: You will need the following parts to build this project. 1. Test Board 2. Cable 3. 12V DC 4. Resistor(33ohms) 5. Pot(50k) 6. Low-density lipoprotein 7. BD139npn (datasheet) 8. Bd140npn (datasheet) 9. 5mmLED BD139 NPN A Bipolar NPN transistor like BD139 is available in the SOT-32 plastic package. This kind of transistor is used in different electronic circuits because of less cost and high collector current. This transistor can drive upto 1.5A loads like motors, high-power LEDs, relays, etc. BD140 PNP The BD140 is a medium-power bipolar junction PNP transistor mainly used for audio amplifiers and drivers utilizing complementary or quasi-complementary circuits. It is made up of silicon and comes in the TO-126 package. The PNP types are BD136 and BD140, and the complementary NPN types are BD135 and BD139. The BD140 can handle current up to 1.5A so that it can drive loads up to 1.5A in electronic circuits like high-power LEDs, relays, motors, etc. The BD140 also has a high collector-emitter and collector-base voltage of 80 V. Its minimum saturation voltage is -0.5V. Moreover, the collector dissipation of BD140 is around 12.5 W hence it is ideal to be used in audio amplifier circuits. Description This circuit will turn on a 1 W LED when there is no light on the LDR face. Circuit operation depends on the change of LDR (Light Dependent Resistor) resistance. After completing the circuit, when the LDR is exposed to a sufficient amount of light, its resistance decreases. This then causes the voltage at the base of the PNP transistor to also drop. When the LDR is exposed to a dark environment, its resistance increases, causing the voltage at the base of the PNP transistor to also increase. This voltage acts as a control signal for the BD139 NPN transistor, which triggers the output LED connected to a 33Ω 1W resistor. The control signal at the bottom of the PNP transistor can be tuned using a 50K potentiometer. Application Used as an emergency backup for security systems and industrial sites. It can be used as an emergency light in both home and office settings. It can be used in study rooms and workplaces to avoid sudden power outages.
  2. A Lenovo G710 has been delivered to me for repair. It was simple to fix the broken power plug. Yet, there is no power or charge. I discovered a transistor that had a short between the base and emitter, preventing something from turning on. really challenging to follow those minute traces and vias. Although I only brought the MMBT3904 on bitfoic electronics, I can replace it. The only significant difference between the PMBS3904 and the MMBT3904 is that the MMBT3904 has a 200mA collector current while the PMBS3904 only has a 100mA collector current. The issue is that while the MMBT3904's Max base current is 200mA, the PMBS3904's is only 100mA. There is no mention of anything more than 100mA when the gain for both is the same. Can they be interchangeable as is or should I order the PMBS3904? If needed, please check the MMBT3904 datasheet
