Electronically curious
9 -
Everything posted by Electronically curious
Okay, I had check the condenser mic and it's not drawing any current since the Zener diode voltage remained the same if I take out the mic and put it back. But I do notice that if I took out the RTS0072 chip. The voltage increased a bit but when I put it back, it decreases. Unless it's supposed to do that. I also noticed that if I touched some of the jumper wires, the speaker produces different tones.
Okay thank you. I got back and I measured them. Speaker: 6.136V Pin 6 of LM386: 6.169V Mic: 1.585V Pin 11 & 12 of the RTS0072: 1.693V Pin 1, 2, 8, and 9 of the RTS0072: 0.797V Ground connections: Around 0.000V I can see that there's something wrong around the yellow area but I'm not sure why. Are you able to assist me with it?
Hi there, thank you for replying. I had switched the polarity of the MIC and they still don't work either way. I also had adjusted the potentiometers to a low setting unless I connect it wrong. I took a photo of my prototype and hopefully you could see it well and also my BOM.Bill of Material (BOM).pdf
Hi there, thank you for replying and willing to assist me. I will provide the schematic of the circuit and a closeup photo of my prototype as soon as I get back. I will also upload the list of components I used to prototype the device. The circuit is based on a voice changer project which can be found in this link: Voice Changer - Electronics-Lab.com
I'm currently prototyping the device using the breadboard and I replaced the AP8072 IC with RTS0072. While testing it, the speaker only produces nosie and when trying to speak into the microphone, it doesn't work. I rechecked the wiring and the components but they're all in good condition and correct. I currently needed assistance with it and will appreciate it if you could provide some assistance with it. Thank you.
