Munir Muhammad
Members
  • Posts
    1
  • Joined
  • Last visited
Everything posted by Munir Muhammad
  1. In this tutorial, we will demonstrate how to build an efficient overload motor protection system using an Arduino and a current sensor. Motor overload can lead to overheating and damage, so it's crucial to implement a reliable protection mechanism. We will explain the working principle of the system and provide a step-by-step guide on connecting the current sensor to the Arduino. Additionally, we will showcase the programming code required to monitor the motor's current and trigger a protective action if an overload is detected. Whether you're a hobbyist or an engineer, this video will equip you with the knowledge to safeguard your motors effectively. Code:- #define Relay A1 int analogPin = A0; // Current sensor output long int sensorValue = 0; // variable to store the sensor value read void setup() { Serial.begin(9600); // setup serial pinMode(Relay, OUTPUT); } void loop() { sensorValue = analogRead(analogPin); // wait 2 milliseconds before the next loop delay(200); Serial.println("ADC Value: "); Serial.println(sensorValue); // set value on which you want to switch off Motor. normally motor oprate between value 512 to 525. // I set 530 value on which motor switch off for 5 seconds. //if(sensorValue > 530) if(sensorValue > 550) { digitalWrite(Relay, LOW); delay(5000); } else { digitalWrite(Relay, HIGH); } } Click to Watch Video of this Project
