25 -
Calendar
Everything posted by nanopoylos
well not all work with pic's some work with resistors but you are right , i did something wrong please tell me what to buy from maxim to build a stereo active xover 3 way , or 2 way or some links thnx
hello guys i wanted to make an active filter for my car nothing special no need to be adjustable , no need to have more gain , my car r/cd is 4 volts preout i found some very interesting chips in maxim active filters with programmable q,f0,anything i bought some ic's from maxim max262,264,265,274,275,278 i have the documentation but its very complicated to me i am ascing if someone has a site with ready projects for this chips or with other chips i do not want to use op-amps nad calculate anything on the paper , i just cant , i do not know how to do that i think the project with maxim is much more easy but i cant make it work please help me anyways thank you
my digital multimeter is a true rms meter when i am measuring a signal 1khz 1Vpp , it does not show me the peak value , but the rms value is there any way to read the peak value? (even with the max feature on , it shows me the max RMS value , not the peak value) another problem is that with my osciloscope i do not see that the rms value is correct , it has a +/- 5% up or down why is this happening? example when i see 1 volt Vp on osciloscope Vp (not Vpp) in the multimeter i should read 0,707 ? right or wrong .Because i read 0.667 . where is the problem ? thnx
hi , i am looking for software for my protec 506 rs232 multimeter does anyone know where to find any? the stock software is very poor please help me thank you
A VERY usefull circuit , but how...
nanopoylos replied to nanopoylos's topic in Electronic Projects Design/Ideas
thank you for replying actualy i think tha t you both are right GPG is right cause what i saw was on a mixing deck , and not a power amp Audioguru is right too for the problems he said that tis project has anyway , what can we do to make the project? i think the solution of the 3 leds was pretty good maybe i will try the project from westhost , ive seen many projects from there and they are all good what about the LM? wich should i use? i am interested on a output indicator for the ffinal amp the inputs to the final amp are beeing set by an osciloscope , so they do not clip .They outpts maybe will clip i am waiting for a new reply ! -
Thank you for replying as for the project i cant understand the diference between a project for an power amp and a project for a mixing console as you say they are not the same well , i set the gains for my amp with an osciloscope , so the inputs are not clipping for sure but what about the output of the final amp? That is what i want to monitor , the outputs I think GPG is right , a mixing console is not an power amp But i think that audioguru is also right for the problems with the output of an power amp so what can we do? the project audioguru posted is very nice , but complicated , i think i will try it :) . i know the sound.westhost , and the projects are very good , and the explanations are too :) my idea was not to use an IC , but i think this cant be done , i dont know , you know ! -
Guys congratulations for the project i only want to see the whole project with all the adjustments you made i mean the replies ended and if someone wants to build the circuit , he must read the whole article and fix the things that must be changed resend the final version with schematic THANK you very much!!!
I was on a studio , and i saw a 32 channels console for recording. I noticed on EACH channel 3 leds A yellow , that showed PRESENT of signal (guess -20dB) A green that showed 0 dB signal A red (non adjustable !?) that showed distorsion , clipping So , i think , if this console has 32 circuits like this , they must not be very complicated Imagine how usefull circuit can it be , on the car amp , on the home amp , on everething !!! For us who construct usefull projects , i think this is a MUST HAVE I think even only red and yellow leds are fine , forget the green led !! But there must me some adjustment because each one will use this project on diferent purposes (amps with diferent amps , etc) the clipping means present of dc , negative or positive , so that time the led flashes the yellow led should have some transistor that can find low signals for the green led i can not imagine the circuit the whole circuit its impossible for me to find (i am a newbee in advanced electronics,IC's etc), but a electronic i think can make it !! So i say lets start building this , and put it on every audio source we have (calm down :P) More than that we make it even better if forum's readers have anything else to suggest Go GO GO electronic maniacs! i am dying to see a diagram ;D
Thanks for replying Actually it is a function generatos with max frequency 2MHz I tied the TTl output in my osciloscope and i found a +4Volt signal (the dc offset doesent work in TTL output) I really cant understand where to use this signal If someone knows please tell me Now ,about the dc offset you were right I thought that the +/- dc offset was something like a clipping signal (like when an amp is clipping its output) In my osciloscope when i was in ac mode and i was checking the output i found a signal like a clipping output of an amp when i adjusted the dc offset knob But in DC mode , i found that the dc offset is what the reply was talking about . I cant still understand what the sweep in is . I really want to use sweep signal , and i dont know how it works!! As for the coaxial cable i have some questions.Why should i use coaxial cable? When i want to drive an external amp with the generator i shouldT use a coaxial? The end of the cable should be RCA !!!! And final question : Can i drive for example a speaker direct from the generator? Or should i drive an amp for example and then a speaker? THANK YOU ALL
Hi friends a very simple problem. i use a acoustic generator and i do not have the manual My generator has 1 input and 2 outputs in BNC The one output is called TTL out .WHAT IS THIS??? How does it works? The second output is the 50Ohm output. 50 ohms is its internal resistance? The input is called Sweep in. What is this and how does it works? Another problem is the DC offset button and the +/- offset trimmer .What are they and how do they work ? when do we need them? I know many things about acoustic,electronics , but it is my first time with an acoustic generator PLEASE HELP THANK YOU ALL!!
ok so i must measure the thd% of the amplified output with 4 ohms load . How should i do this?? i mean , if i connect to the output the load , where should i connect the measuring cables and where the attenuator circiut? Do i still need the attenuator circuit? What about the preouts? do they need load so i can measure the thd? and if yes , what load should i connect to them . The preouts are for connecting the input stage of an amp , not a speaker... Another question : if i am using an acoustic generator and an osciloscope (not to the pc) , the things are easier? Can an osciloscope measure the harmonic distorsion?Or i only see when the graphic starts to clip? With an osciloscope i do not need an attenuator?
HI I would like to construct a device wich will have a motor,20 inputs of fluids and an output. The pc will have a programm to tell to the device wich fluid must be connected to the output each time and for how long. The selector will be in circle shape , on the one side the inputs , in the center the motor , and to the other side the output. The pc must know the position of the selector any time , and the pc must know when the selector is beeing "locked " to each output . The pc must be able to tell the selector where to go toconnect the correct fluid to the output. So, how should i do this? Do i need a step motor?a servo? How will the pc able to know the position of the selector? What programm should i use? What language? Some people told me about plc's , others for pic's , others for just rele's . THNX
Thnx for repluing i do not something strange to attenuate the signal . My car cd player has amplified outputs and preouts. The outputs are 5volts maximum , with no amplification The amplified outputs deliver 17 watts rms at 4 ohms So, i guessed that this ratings are to much for my sound card to handle! So i user a voltage divider (20db) , simply a resistor in series 1000 ohms and a resistor in parallel 100 ohms . Thats all i used to attenuate the output voltage in order not to "burn" my sound card . My second question is : There MUST be some way to measure thd% at high volts and high watts .For example how do we measure thd to an amp with 1000 watts rms ??? Do we attenuate the output? And if the answer is yes , then how much lower ratings do we get? So when i attenuated my output to the cd-layer the measure was right or wrong?
HI I would like to measure thd% on my pc. I use spectra plus software . If i use a low watt device, there is no problem . When i use my car cd-player , the output is 17 watts rms. So i guessed , i should protect my sound car from frying, and i used an attenuator 20db . Now the question is, when i use an attenuator , i get lower reading of thd%??? If yes , how can i measure an audio device with enough wattage without using an attenuator?? please help me. thnx
HI THERE. we all know that we can build amps for home use . I would like to construct an amp for use in my car , with 12V supply . Inorder to achieve many Watts , we should raise the voltage of the car battery to 40 or ever 70 volts . As i know we should use a power converter . I would like to have a diagramm or an idea of how i can do it .
Hi I would like to construct a device that will be connected to the parallel port of my pc , and i would be able to control RELE's . I dont know if i can find something like that ready or i should construct it from scratch . The device must be controlled by a windows programm, that i must construct .This programm would control the device as i want , for example , to enable the rele's as i want , for as long that i want .It should be able to accept schedule for seconds , minutes , or hours . I dont know wich language should i use to build the program . If someone knows what should i do at all , please reply, i must construct it since it is part of a medical machine i like to construct. ThANK U
