Showing results for tags 'arm development board'.
  • Search By Tags
  • Search By Author
  • Electronics Forums
    • Projects Q/A
    • Datasheet/Parts requests
    • Power Electronics
    • Service Manuals
    • Theory articles
    • Electronics chit chat
    • Microelectronics
    • Electronic Resources
  • Related to Electronics
    • Inventive/New Ideas
    • Components trade
    • High Voltage Stuff
    • Electronic Gadgets
  • General
    • Announcements
    • Feedback/Comments
    • General
  • Salvage Area
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Yahoo
Skype
Location
Interests
Found 1 result
  1. Installing Linux on an ARM development board can be complex, but this detailed guide will walk you through each step from preparation to booting Linux. 1. Preparation Before you start, gather the following tools and software: A computer running Linux An ARM-based development board A USB-to-serial adapter A Micro USB cable An SD card reader A blank SD card A USB keyboard and mouse (optional) An HDMI monitor (optional) Download Linux Kernel and Root Filesystem Download the appropriate Linux kernel and root filesystem for your ARM board from the official site (Neardi offers download links). Save them in a temporary folder on your computer. Create Bootable SD Card You will use the SD card as the boot medium. Insert the SD card into the reader and connect it to your computer. Open a terminal and run: $ sudo fdisk -l This lists all disk devices. Identify the device node for your SD card (e.g., /dev/sdb). 2. Unmount all partitions on the SD card: $ sudo umount /dev/sdb* 3.Create a new partition table and partition: $ sudo fdisk /dev/sdb Use the n command to create a new partition, set it to Linux filesystem type using the t command, and save with the w command. 4. Format the partition: $ sudo mkfs.ext4 /dev/sdb1 5. Create a mount point and mount the partition: $ sudo mkdir /mnt/sdcard $ sudo mount /dev/sdb1 /mnt/sdcard 6. Extract the root filesystem to the SD card: $ sudo tar zxvf rootfs.tar.gz -C /mnt/sdcard Install and Configure the Bootloader Remove the SD card from your computer and insert it into the development board. Connect the board to your computer using the USB-to-serial adapter. Open a terminal and use a serial tool (like minicom or picocom) to connect: $ sudo minicom -D /dev/ttyUSB0 Press Enter to access the command line. 3. Find the device node of the boot SD card: $ fdisk -l Note the path for later use. 4. Install the bootloader to the SD card: $ sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/sdX bs=1024 seek=8 Replace u-boot-sunxi-with-spl.bin with your bootloader file path and /dev/sdX with your SD card’s device node. Then, reinsert the SD card into the board. 5. Copy the kernel image to the boot SD card: $ sudo cp zImage /mnt/sdcard/boot Replace zImage with your actual kernel image file path. 6. Copy the device tree file: $ sudo cp sun8i-h3-orangepi-one.dtb /mnt/sdcard/boot Replace with your device tree file path. 7. Create a boot.cmd file in the /mnt/sdcard/boot directory and add: setenv bootargs console=ttyS0,115200 root=/dev/mmcblk0p1 rootwait panic=10 fatload mmc 0:1 0x4000000 zImage fatload mmc 0:1 0x42000000 sun8i-h3-orangepi-one.dtb bootz 0x4000000 - 0x42000000 Save and close the file. 8. Compile boot.cmd into a binary: $ sudo mkimage -C none -A arm -T script -d boot.cmd boot.scr Then copy it to the boot directory: $ sudo cp boot.scr /mnt/sdcard/boot Unmount the SD card and insert it into the development board. Boot the Development Board Connect the USB keyboard and mouse (if available) and an HDMI monitor. Power on the board. During the boot process, you should see Linux startup messages on the HDMI display. If successful, you’ll reach a login prompt. Enter the default username and password, or the credentials you set, to access the Linux command line.
