Showing results for tags 'audio amplifier'.
Hi everyone, I just did a design of lm386 audio amplifier circuit and get a problem, Design steps: First, think about the chip based on its function, thus designing the circuit Second, to understand the nature of the chip, characteristics. Third, use DXP software to draw the circuit schematic. I could not use DXP software, how to fix?
4558 ic Audio Power Amplifier Circuit Diagram circuitspedia.com This is circuit diagram of powerful audio amplifier. This circuit is given by Emmanuel. In this circuit one ic 4558 and 4 Power transistors are used with some discrete components. Use 20v-to 60v for operating this circuit. This is a single channel audio amplifier circuit. Use capacitor of minimum 50v value. Positive supply voltage is given at the middle pin of both transistor TIP41C and D718. Negative supply is given at middle terminal of D688and TI42C Transistor. R1 is the variable resistor potentiometer for volume control. This vol. control may be value of 50k to 100k. Use Big size speaker with this circuit. 4558 Audio Amplifier Circuit Diagram. In image of assembled kit there is no 5w resistor connected for more Amplifier circuit click here
- 13 replies
- audio amplifier
- audio power amplifier
- (and 4 more)
