Showing results for tags 'condenser microphone connection'.
Homemade MIC Amplifier Loudspeaker connection circuit You can connect condenser MIC with any amplifier circuit as given below diagram . This circuit will work very well with any type of Audio amplifier. Use only 3-5v for condenser MIC for best result. Audio amplifier circuit need 6-24v as per amplifier specification. Connect the positive terminal of mic with 22k resistor in series with positive supply and negative terminal of mic is directly connected to negative supply or ground. And enjoy this easy homemade MIC Loudspeaker. This Circuit works with any type of amplifier circuit. If you have no any audio amplifier then you can make an small amplifier very easily with LM386 ic. This is very popular amplifier ic and available on any electronic part store. For more Click here You can check for more simple circuit here circuitspedia.com
- 1 reply
- condenser microphone connection
- condenser mic
- (and 1 more)
