Showing results for tags 'hand sanitizer dispenser'.
Features High stability and no sensitivity to the ambient light Laser-cut acrylic (plexiglass) enclosure Cost-effective Flow control capability of the hand-sanitizer/alcohol (efficiency) Through-hole components (easy to solder) Single-layer PCB board (easy to fabricate) Single and cheap ATTiny13 microcontroller Low standby current consumption As we all know, the COVID-19 outbreak hit the world and changed our lifestyle. In this condition, alcohol and hand sanitizers are vital, expensive, and in some areas hard to find fluids, so, they must be used properly and efficiently. In the second version of the hand sanitizer dispenser device, I have addressed the previous design problems and introduced a device with no sensitivity to the ambient light and flow control capability of the alcohol/sanitizer. Therefore just enough amount of liquid will be poured on each request. The design uses a cheap ATTiny13 microcontroller. References Source: https://www.pcbway.com/blog/technology/Automatic_Hand_Sanitizer_Dispenser__Version_2___Using_ATTiny13.html [1]: TSOP1738 datasheet: https://www.batronix.com/pdf/tsop17xx.pdf [2]: 2N7000 datasheet: https://www.onsemi.com/pub/Collateral/NDS7002A-D.PDF [3]: ATTiny13 datasheet: https://componentsearchengine.com/Datasheets/1/ATtiny13-20PU.pdf [4]: BD139 datasheet: https://www.st.com/resource/en/datasheet/bd140.pdf [5]: 2N7000 schematic symbol and PCB footprint: https://componentsearchengine.com/part/1011182/model/download [6]: BD139 schematic symbol and PCB footprint: https://componentsearchengine.com/part/1041398/model/download [7]: ATTiny13 schematic symbol and PCB footprint: https://componentsearchengine.com/part/235118299/model/download [8]: CAD Plugins: https://www.samacsys.com/library-loader-help
- 1 reply
- ambient light
- hand sanitizer dispenser
- (and 4 more)
As we all know, the COVID-19 outbreak hit the world and changed our lifestyle. In this condition, Alcohol and hand sanitizers are vital fluids, however, they must be used properly. Touching alcohol containers or hand sanitizers with infected hands can spread the virus to the next person. In this article, we will build an automatic hand sanitizer dispenser that uses IR sensors to detect the presence of a hand and activates a pump to pour the liquid on the hand. The intention was to find the cheapest and easiest solution and design a circuit. Therefore no Microcontroller or Arduino has been used. Two designs have been introduced and you are free to select and build any of them. The first design uses SMD components and the second design is even simpler. It uses DIP components on a small single layer PCB board. References Article: https://www.pcbway.com/blog/technology/DIY_Automatic_Hand_Sanitizer_Dispenser__without_Arduino_or_MCU.html [1]: AMS1117-5.0 Datasheet: http://www.advanced-monolithic.com/pdf/ds1117.pdf [2]: LM555 Datasheet: http://www.ti.com/lit/ds/symlink/lm555.pdf?&ts=1589508422474 [3]: TSOP1738 Datasheet: https://eu.mouser.com/datasheet/2/427/introductionpartnumbers-1766653.pdf [4]: NDS356 Datasheet: https://eu.mouser.com/datasheet/2/308/NDS356AP-D-1813031.pdf [5]: AMS1117-5.0 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=2376678 [6]: LM555 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=380204 [7]: TSOP1738 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=1116997 [8]: NDS356 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=840198 [9]: CAD Plugins: https://www.samacsys.com/library-loader-help [10]: LM393 Datasheet: http://www.ti.com/lit/ds/symlink/lm393-n.pdf?&ts=1589509317025 [11]: BD140 Datasheet: https://www.mouser.com/datasheet/2/149/BD140-888626.pdf [12]: LM393 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=298790 [13]: BD140 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=166782
- 3 replies
- hand sanitizer
(and 2 more)
Tagged with:
