Showing results for tags 'laser'.
DIY Laser Range Finder (1mm Accuracy)
sam.moshiri posted a topic in Electronic Projects Design/Ideas
In this article/video, I used an RP2040 Zero board, a VL53L0X Laser time-of-flight ranging sensor, and a 2.4” TFT display to build a graphical laser rangefinder unit that can be used to monitor the distance, check the liquid level, etc. The board is also equipped with a relay and a buzzer that allow the user to provide distance-related acoustic signals or activate/deactivate an external device, such as a pump, brake, etc. Source: https://resources.altium.com/p/rp2040-zero-powered-laser-range-finder-gui-and-24-tft-display- 1 reply
- laser
- range finder
- (and 4 more)
Hello.Looking for information on the fastest arduino infrared temperature sensor.If there are sensors out there that can sense between 100 and 300 ms,sensors don't have to be arduino,but there must be ready made interface boards and compatible software.Any assistance will be greatly appreciated. Thank you Regards Arthur
