Showing results for tags 'micropython'.
  • Search By Tags
  • Search By Author
  • Electronics Forums
    • Projects Q/A
    • Datasheet/Parts requests
    • Power Electronics
    • Service Manuals
    • Theory articles
    • Electronics chit chat
    • Microelectronics
    • Electronic Resources
  • Related to Electronics
    • Inventive/New Ideas
    • Components trade
    • High Voltage Stuff
    • Electronic Gadgets
  • General
    • Announcements
    • Feedback/Comments
    • General
  • Salvage Area
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Yahoo
Skype
Location
Interests
Found 7 results
  1. PWM is one of the crucial peripheral of an MCU, with MicroPython, you can control RTL8722DM to output PWM signal to fade and brighten an LED with ease, here is how, Materials Ameba x 1, LED x 1, Resistor(220ohm) x 1 Steps PWM use pulse width modulation to control output duty cycle and is widely used to control LED brightness and motor. Here we are using an LED to demonstrate how PWM works. Let us connect pin PA_26 to the anode leg of an LED which in series with a current limiting resistor and GND to cathode of the LED as shown below, Then,
  2. Sometimes we need to exchange some data with another microconrtoller in close range, then we can use I2C for this job, even better, with MicroPython, we can do it in less than 5 lines of code, here is how it's done on ameba RTL8722 from Realtek, Materials Ameba x 1, Arduino UNO x 1 Steps I2C is a very common module on microcontrollers, it only takes 2 wire and able to achieve data rate at up t
  3. Controlling LED has never been easier with MicroPython on Ameba RTL8722 WiFi and BLE microcontroller, today I am gonna show you just how to blink an LED in 3 different ways! Materials Ameba x 1, LED x 1, Resistor(220ohm) x 1 Steps Blink is one of the best examples to get started with MicroPython. Let us connect pin PB_22 to the anode leg of an LED which in series with a current limiting resistor and GND to cathode of the LED as shown below, Then, copy the following code and press Ctrl + e in REPL to enter the paste mode (for more informatio
  4. RTL8722 from Realtek supports MicroPython and reading ADC values using Python script in 3 lines, here is an example ADC read potentiometer: • Materials: Ameba x 1, potentiomete x 1 • Steps: Here we connect ameba to a potentiometer to measure its analogue value, the connection is as follows. Copy and paste the following code into REPL. from machine import ADC a = ADC(0) a.read()
  5. Microcontrollers are known for its low power usage and limited resources thus often deemed unable to understand Python script as Python need interpretor to translate script into machine langauge and intepretor are usaully quite resource-consuming. However, MicroPython has arisen as a lean and efficiant Python 3 interpretor that can be run on ARM Cortex-M series microcontrollers. Ameba RTL8722 is an ARM Cortex-M33 microcontroller that has dual-band WiFi and BLE 5.0, other than that it is fully capable of running MicroPython and controls WiFi using Python script. In addition, its req
  6. This is MicroPython project developed using Ameba RTL8722. MicroPython is offically supported on Ameba RTL8722, so through this demo video, we will see how easy and fast it is to develop a simple server socket on Ameba, which would then control other peripheral to perform other tasks. Here we are using a client socket code running on PC to send a 'Hello, world' string via the WiFi network, Ameba receives it and if it is indeed 'Hello, world' then it will blink the LED. Check out the demo video down below, https://youtu.be/pEMkwvw-r18 Code used: #!/usr/bin/e
  7. RTL8722 MicroPython SDK alpha release It was annouced that the popular MicroPython project has been ported to ameba RTL8722, with support for peripheral control and Python 3 syntax, you may now control RTL8722 not only with Arduino but also with Python language on the REPL. The SDK is currently in alpha stage and WiFi feature is going to release soon. If you are interested , please find links to the SDK on Github at. https://github.com/ambiot/ambd_micropython?fbclid=IwAR0TxWN06-XT88AfIZbPaBOYJ5fyhh3pMOe-X1RC48Tgari0rXn3nHhEyTo Here are introduction and basic examples to this
