Showing results for tags 'proteus'.
  • Search By Tags
  • Search By Author
  • Electronics Forums
    • Projects Q/A
    • Datasheet/Parts requests
    • Power Electronics
    • Service Manuals
    • Theory articles
    • Electronics chit chat
    • Microelectronics
    • Electronic Resources
  • Related to Electronics
    • Inventive/New Ideas
    • Components trade
    • High Voltage Stuff
    • Electronic Gadgets
  • General
    • Announcements
    • Feedback/Comments
    • General
  • Salvage Area
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Yahoo
Skype
Location
Interests
Found 4 results
  1. BCD calculator with two input(A,B).. do (add,subtraction, multiplication, division at a time) using proteous anyone?
  2. Hello friends, hope you all are fine and having fun with your lives. In today’s post we are gonna have a look at How to use Temperature Sensor 18B20 in Proteus ISIS. I will use Arduino board as a microcontroller and will connect the temperature sensor with it and then will display the code on LCD. I have already posted the same tutorial in which I have done Interfacing of Temperature Sensor 18B20 with Arduino but in that project I have used the real components and designed the hardware. But today, I will just show you the simulation so that you could test the simulation first and then design it in hardware. Temperature Sensor 18B20 is the most commonly used temperature sensor. Its a one wire sensor means it sends data through a single wire and we can connect multiple sensors with a single wire, that’s why its quite efficient and easy to use as well. I have also posted a tutorial on How to Interface LM35 sensor with Arduino in Proteus ISIS which is another temperature sensor so give it a try as well and let me know which one you think is better. Anyways let’s get started with temperature sensor 18B20 in Proteus ISIS. HOW TO USE 18B20 IN PROTEUS ISIS First of all, get these components from Proteus components list as shown in below figure: Now design the circuit as shown in below figure: As you can see in above simulation, we have used Arduino UNO board along with LCD and 18B20 temperature sensor. 18B20 in Proteus can’t detect the real temperature but we can change the temperature by pressing + and – buttons. So, now we have interfaced the temperature sensor and the LCD with Arduino. Next we are gonna design the code for Arduino and will upload it in Arduino baord. Note: If you don’t know How to use Arduino in Proteus then read Arduino Library for Proteus. You should also read How to get Hex File from Arduino, as Arduino software doesn’t generate the hex file. Now download these three libraries, one is “one wire” library which is the protocol for 18B20 temperature sensor, next is the Dallas Temperature sensor library which is the actua library for temperature sensor 18B20 and uses one wire library. Third library is the Crystal LCD library which is used for displaying character on LCD. So, download all these three libraries by clicking on below buttons and then paste them in your libraries folder of Arduino software. Download One Wire LibraryDownload Dallas Temperature LibraryDownlaod Liquid Crystal Library Now after adding these libraries, open your Arduino software and paste the below code into it. #include <OneWire.h> #include <DallasTemperature.h> #include <LiquidCrystal.h> #define ONE_WIRE_BUS 6 OneWire oneWire(ONE_WIRE_BUS); DallasTemperature sensors(&oneWire); LiquidCrystal lcd(12, 11, 5, 4, 3, 2); void setup(void) { Serial.begin(9600); Serial.println("Welcome to TEP !!!"); Serial.println("www.TheEngineeringProjects.com"); Serial.println(); sensors.begin(); lcd.begin(20, 4); lcd.setCursor(5,0); lcd.print("Welcome to:"); lcd.setCursor(1,2); lcd.print("www.TheEngineering"); lcd.setCursor(4,3); lcd.print("Projects.com"); delay(5000); } void loop(void) { sensors.requestTemperatures(); Serial.print("Temperature : "); Serial.println(sensors.getTempCByIndex(0)); //lcd.clear(); lcd.setCursor(0,0); lcd.print("Temperature: "); lcd.print(sensors.getTempCByIndex(0)); lcd.print("C"); delay(1000); } Now get your hex file from Arduino and upload it to your Proteus Arduino board and hit the RUN button. If everything goes fine then you will something like this at the start: After a delay of around 5 sec you will start receiving the Temperature sensor 18B20 values on your LCD as shown in below figure: Now you can see the value shown in the temperature sensor is the same as in LCD. So, now by clicking the + and – buttons on temperature sensor, you can increase and decrease the value of temperature and same will be changed in LCD. That’s how you can do simulation of Temperature sensor 18B20 in Proteus ISIS. Its quite simple and easy to use. That’s all for today, hope you get some knowledge out of it.
  3. Hello friends, we have designed many Proteus Libraries on our blog The Engineering Projects which are not yet developed and we are really very proud that we are the first designers for these Proteus Libraries. I am gonna share all those Proteus Libraries in this instructable so that Engineering Students can download them and use them in their Projects. I have also designed their videos in which I have explained in detail How to use these Proteus Libraries. So, you can join our You Tube Channel to have a look at these Proteus Libraries. Here are the links: Our YouTube channel: https://www.youtube.com/channel/UCbVgl6VOoqgq8FalMq6vikw Our Facebook Page: https://www.facebook.com/theengineeringprojects So, let's get started with these New Proteus Libraries for Engineering Students: Step 1: Links to Download New Proteus Libraries Here are the links to our New Proteus Libraries: Arduino Library for Proteus Genuino Library for Proteus GPS Library for Proteus GSM Library for Proteus XBee Library for Proteus Arduino UNO Library for Proteus Arduino Mega Library for Proteus Arduino Nano Library for Proteus Arduino Pro Mini Library for Proteus Ultrasonic Sensor Library for Proteus PIR Sensor Library for Proteus Bluetooth Library for Proteus DS1307 Library for Proteus Gas Sensor Library for Proteus Vibration Sensor Library for Proteus Flame Sensor Library for Proteus
  4. Hello friends, we have designed many Proteus Libraries on our blog The Engineering Projects which are not yet developed and we are really very proud that we are the first designers for these Proteus Libraries. I am gonna share all those Proteus Libraries in this instructable so that Engineering Students can download them and use them in their Projects. I have also designed their videos in which I have explained in detail How to use these Proteus Libraries. So, you can join our You Tube Channel to have a look at these Proteus Libraries. Here are the links: Our YouTube channel: https://www.youtube.com/channel/UCbVgl6VOoqgq8FalMq6vikw Our Facebook Page: https://www.facebook.com/theengineeringprojects So, let's get started with these New Proteus Libraries for Engineering Students: Step 1: Links to Download New Proteus Libraries Here are the links to our New Proteus Libraries: Arduino Library for Proteus Genuino Library for Proteus GPS Library for Proteus GSM Library for Proteus XBee Library for Proteus Arduino UNO Library for Proteus Arduino Mega Library for Proteus Arduino Nano Library for Proteus Arduino Pro Mini Library for Proteus Ultrasonic Sensor Library for Proteus PIR Sensor Library for Proteus Bluetooth Library for Proteus DS1307 Library for Proteus Gas Sensor Library for Proteus Vibration Sensor Library for Proteus Flame Sensor Library for Proteus
