Showing results for tags 'raspberry pi 2'.
With the possibility of 3D hardware graphic acceleration on Raspberry Pi, it becomes much easier to play great PC Games on RPi. Thanks to OpenGL and new ExaGear emulator feature. Learn more from the article above.
- 1 reply
- rpi gaming
- rpi3
- (and 9 more)
My personal user-case on how to make Skype work great on Raspbian. For me, this result seems a bit faster and more stable video streaming and less overall lagging. Learn from my Skype on Raspberry Pi article. P.S. This guide is likely to be applicable to other ARM devices.
- raspberry pi 2
- raspberry pi 3
- (and 8 more)
There are a lot of ways to use the Raspberry Pi (and other ARM-based) mini computer boards. I've wondered if it's possible to make up something like a music controller hub center with Spotify. So, read my experiment about running Spotify on RPi
- raspberry pi 2
- raspberry pi 3
- (and 10 more)
There is a real necessity in a TeamSpeak server to organize communication channel between two and more people. Also, it needs to to be built in a cost-efficient and tech-savvy way. And so, I've come to the solution - build TeamSpeak 3 server on Raspberry Pi (or any other ARM device). Learn this case and try to do this on your ARM.
- raspebrry pi
- raspberry pi 2
- (and 9 more)
To emulate any type of software on any ARM development boards like Raspberry Pi a Virtualbox software is usually used. Learn the Virtualbox alternative for RPI (or any other ARM) with greater performance.
- raspberry pi 2
- raspberry pi 3
- (and 11 more)
Another and less complicated way to enjoy Plex on your Raspberry Pi (or any other ARM Device)
- raspberry pi
- raspberry pi 2
- (and 8 more)
It's great when you've got your own cloud storage server. OwnCloud is the one, that can help. Especially, if set up on an ARM-device (like Raspberry Pi) it is also savvy and simple. Learn my experience how I have succeeded to install OwnCloud on Raspberry Pi (if you like it and have some other ARM device, go ahead and try this tutorial. Post the results to this topic)
- raspberry pi 2
- raspberry pi 3
- (and 6 more)
