Showing results for tags 'raspbian'.
There are a lot of ways to use the Raspberry Pi (and other ARM-based) mini computer boards. I've wondered if it's possible to make up something like a music controller hub center with Spotify. So, read my experiment about running Spotify on RPi
- spotify on raspberry pi
- raspberry pi projects
- (and 10 more)
With the possibility of 3D hardware graphic acceleration on Raspberry Pi, it becomes much easier to play great PC Games on RPi. Thanks to OpenGL and new ExaGear emulator feature. Learn more from the article above.
- 1 reply
- raspbian
- raspberry pi 3
- (and 9 more)
There is a real necessity in a TeamSpeak server to organize communication channel between two and more people. Also, it needs to to be built in a cost-efficient and tech-savvy way. And so, I've come to the solution - build TeamSpeak 3 server on Raspberry Pi (or any other ARM device). Learn this case and try to do this on your ARM.
- raspebrry pi
- raspberry pi 2
- (and 9 more)
Another and less complicated way to enjoy Plex on your Raspberry Pi (or any other ARM Device)
- plex on raspberry pi
- plex
- (and 8 more)
It's great when you've got your own cloud storage server. OwnCloud is the one, that can help. Especially, if set up on an ARM-device (like Raspberry Pi) it is also savvy and simple. Learn my experience how I have succeeded to install OwnCloud on Raspberry Pi (if you like it and have some other ARM device, go ahead and try this tutorial. Post the results to this topic)
- owncloud on raspberry pi
- owncloud
- (and 6 more)
Communication is great when it's easy and free. Here is the way to setup the popular messenger Telegram on Raspberry Pi
Have you ever thought about a passive income? Try automated Forex trading made with Raspberry Pi (or any ARM) and a trading platform - MetaTrader 4. And here is an instruction on how to setup MT4 on Raspberry Pi
- 1 reply
- forex
- rpi projects
(and 8 more)
Tagged with:
Free open-source and cross-platform alternative to Microsoft .NET Framework is Mono and it also can be ported to Raspberry Pi. Read more: Mono on Raspberry Pi
- mono on raspberry pi
- .net framewotk
- (and 4 more)
What if Windows can be started on ARM devices? Do you really need to reach your goals? The answers are in the article: Windows 7 on Raspberry Pi
- windows 10
- wins\dows
(and 7 more)
Tagged with:
Another way of playing great PC games on Raspberry Pi. Simply turn your device into a fast Raspberry Pi gaming emulator
- games on raspberry pi
- raspberry pi gaming
- (and 3 more)
Some developers really need MS .NET Framework for some reason on their ARM devices (mainly on Raspberry Pi). So, basing on their requests, I have made a short tutorial on how to setup .NET on Raspberry Pi.
Here is a good way to setup VPN using Raspberry Pi device.
- raspberrypi
- rpi
(and 1 more)
Tagged with:
TeamViewer, VNC or SSH + X11 are the 3 ways to run a remote desktop on Raspberry Pi. Learn the details from my article and chose the best one for you.
- remote desktop on raspberry pi
- (and 3 more)
If you need to build up an automatic backup process on an ARM device, learn this tutorial for setting up CrashPlan on Raspberry Pi as an example. You may use this for any ARM-based device as well.
- raspberrypi
- raspberry pi
- (and 5 more)
