Showing results for tags 'switching power supply'.
  • Search By Tags
  • Search By Author
  • Electronics Forums
    • Projects Q/A
    • Datasheet/Parts requests
    • Power Electronics
    • Service Manuals
    • Theory articles
    • Electronics chit chat
    • Microelectronics
    • Electronic Resources
  • Related to Electronics
    • Inventive/New Ideas
    • Components trade
    • High Voltage Stuff
    • Electronic Gadgets
  • General
    • Announcements
    • Feedback/Comments
    • General
  • Salvage Area
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Yahoo
Skype
Location
Interests
Found 5 results
  1. The key part of any electronic device is the power supply. Any instability or malfunction of the power supply part causes the device to stop working or demonstrate weird behavior. In this article/video, I introduced an AC-to-DC flyback Switching power supply that converts 85V-260VAC to 5VDC-2.5A, which can be used in various applications. The 5V selection for the output makes it friendly for linear regulators that convert 5VDC to lower voltages. The maximum power delivery of this power supply is around 12W, which means it can handle 2.5A at 5V output. The controller chip is DK1203, which does not need any external supply, a startup resistor, or an auxiliary winding on the transformer. The ferrite core of the transformer is EE20. A potentiometer allows you to adjust the output voltage and set it exactly at 5.0V. To design the schematic and PCB, I used Altium Designer 23 and shared the PCB project with my friends for feedback and updates using Altium-365. The fast component search engine, Octopart, proved invaluable in quickly obtaining component information and generating the Bill of Materials (BOM). To ensure high-quality fabricated boards, I sent the Gerber files to PCBWay. I tested the board for voltage drop, current delivery, and output noise. I used Siglent SDL1020X-E DC Load and Siglent SDS2102X Plus oscilloscope to perform all tests. I am confident that building this circuit enhances your knowledge regarding switching power supply design, except for using it for real applications. Schematic + PCB + Transformer: https://www.pcbway.com/blog/technology/85V_260VAC_to_5VDC_2_5A_Flyback_Switching_Power_Supply_b7f49beb.html References [1]: DK1203: https://grupoautcomp.com.br/wp-content/uploads/2016/11/Specification-IC-DK1203.pdf [2]: 500mA Fuse: https://octopart.com/39211000440-littelfuse-39590771?r=sp [3]: 07D471 Varistor: https://octopart.com/mov-07d471ktr-bourns-19184728?r=sp [4]: 100nF X2: https://octopart.com/r463i310050m1k-kemet-50550056?r=sp [5]: UU9.8 Choke: https://octopart.com/7355-h-rc-bourns-12614152?r=sp [6]: MB6M Bridge: https://octopart.com/mb6m-e3%2F45-vishay-42761003?r=sp [7]: 22uF-400V: https://octopart.com/eca2ghg220-panasonic-3578224?r=sp [8]: RS1M Diode: https://octopart.com/rs1m-13-f-diodes+inc.-333072?r=sp [9]: PC817 Optocoupler: https://octopart.com/pc817xnnsz1b-sharp-80823687?r=sp [10]: TL431 Shunt: https://octopart.com/tl431acdbvr-texas+instruments-521839?r=sp [11]: SS54 Schottky Diode: https://octopart.com/ss54-multicomp-18903925?r=sp [12]: 470R-1206: https://octopart.com/cr1206-jw-471elf-bourns-3872844?r=sp
  2. A power supply is an essential tool on every electronics bench. The TPS54202 is a highly efficient 2A synchronous buck converter with a wide 28V input voltage range and low EMI figures, making it suitable for various applications. These features make the TPS54202 an excellent choice for building a power supply. To achieve a low noise level and ensure high performance, I implemented a variety of input and output filters, along with following several PCB design techniques. The chip operates at a switching frequency of 500KHz and is equipped with internal loop compensation. Setting up the power supply is simple—just connect the input to a step-down AC transformer (e.g., 220V to 15V) and use a multiturn potentiometer to adjust the output voltage to your desired level. For the schematic and PCB design, I utilized Altium Designer 23 and shared the project with my friends for feedback and updates using Altium-365. The fast component search engine, Octopart, proved invaluable in quickly obtaining component information and generating the Bill of Materials (BOM). To ensure high-quality fabricated boards, I sent the Gerber files to PCBWay. I tested the circuit for output noise and load step response using Siglent SDS2102X Plus oscilloscope and Siglent SDL1020X-E DC load. I am confident that this circuit will meet your requirements for a compact and efficient power supply, providing reliable performance on your electronics bench. References Schematic + PCB + Gerber: https://www.pcbway.com/blog/technology/Adjustable_Low_EMI_Switching_Power_Supply_9611437d.html [1]: TPS54202: https://octopart.com/tps54202ddct-texas+instruments-71538129?r=sp [2]: 470uF-35V: https://octopart.com/eee-fk1v471aq-panasonic-44406255?r=sp [3]: 22uH-3A: https://octopart.com/etqp5m220yfm-panasonic-24904108?r=sp [4]: 5K Potentiometer: https://octopart.com/ss34a-multicomp-18903924?r=sp [5]: SS34: https://octopart.com/ss34a-multicomp-18903924?r=sp
  3. Flyback is the most common circuit topology to build galvanically isolated AC to DC or DC to DC converters. Flyback circuit is cheap and relatively easy to manufacture, therefore nowadays the majority of home or industrial appliances are powered using AC to DC Flyback converters. In general, a Flyback converter is suitable for low-power applications, mostly below 100W. In this article/video, I designed a cheap AC-to-DC flyback converter using a DK124 IC that can deliver up to 18W continuously. I calculated the transformer to handle 12V at the output which can be easily modified to reach other output voltages as well. The DK124 chip does not need any auxiliary winding or even an external startup resistor. The 220V Mains input has been protected using a MOV, an NTC, and a Fuse. The PCB board is single-layer and all components are through-hole. To design the schematic and PCB, I used Altium Designer 22. The fast component search engine (octopart) allowed me to quickly consider components’ information and also generate the BOM. To get high-quality fabricated boards, I sent the Gerber files to PCBWay. To test the power supply, I used Siglent an SDL1020X-E DC Load, an SDM3045X Multimeter, and an SDS1104X-E/SDS2102X Plus oscilloscope. Specifications Input Voltage Range: 85 to 265V-AC Output Power: 18W Continuous Output Voltage: 12V-DC Switching Frequency: 65KHz Reference: https://www.pcbway.com/blog/technology/220V_AC_to_12V_DC_18W_Switching_Power_Supply_81665a6c.html [1]: DK124: https://grupoautcomp.com.br/wp-content/uploads/2016/11/Specification-IC-DK124.pdf [2]: 10D561: https://octopart.com/mov-10d561k-bourns-19184788?r=sp [3]: PC817: https://octopart.com/pc817x1j000f-sharp-39642331?r=sp [4]: TL431: https://octopart.com/tl431aclpr-texas+instruments-521800?r=sp
  4. Switching power supplies are known for high efficiency. An adjustable voltage/current supply is an interesting tool, which can be used in many applications such as a Lithium-ion/Lead-acid/NiCD-NiMH battery charger or a standalone power supply. In this article, we will learn to build a variable step-down buck converter using the popular LM2576-Adj chip. Features Cheap and easy to build and use Constant current and constant voltage adjustment [CC, CV] capability 1.2V to 25V and 25mA to 3A controlling range Easy to adjust the parameters (optimum use of variable resistors to control the voltage and current) The design follows the EMC rules It is easy to mount a heatsink on the LM2576 It uses a real shunt resistor (not a PCB track) to sense the current
  5. Abstract: A high-quality switching power supply efficiency is as high as 95%, and the switching power supply loss is mostly from switching devices (MOSFETs and diodes), so the correct measurement of switching device losses is critical for efficiency analysis. So how do we accurately measure switching losses? First, switching loss Since the switch is a non-ideal device, its working process can be divided into four states, as shown in Figure 1. "On state" means that the switch tube is in the on state; "off state" means that the switch tube is in the off state; "on process" means that the switch tube is switched from off to on state; "off process" means that the switch tube is from conduction The conversion is turned off. In general, the main energy loss is reflected in the "on process" and "off process", a small part of the energy is reflected in the "on state", and the "off state" loss is very small, almost zero, negligible. Figure 1 Switching tube four state division The actual measurement waveform is generally as shown below: Figure 2 Switch tube actual power loss test Second, the conduction process loss The energy consumed by the transistor switching circuit during the conversion process is usually very large, because the parasitic signal of the circuit prevents the device from switching immediately, and the voltage and current in this state are in an alternating state, so it is difficult to directly calculate the power consumption. The voltage and current are considered to be linear, so the loss can be roughly calculated by finding the area of the triangle, but this is not accurate enough. For digital oscilloscopes, advanced math functions are provided, so the loss of the conduction process can be calculated using the following formula. Eon represents the loss energy of the conduction process Pon represents the average power loss (active power) during the conduction process Vds and Id represent instantaneous voltage and current, respectively Ts indicates the switching period T0, t1 indicate the start time and end time of the conduction process Shutdown process loss The closing process loss is the same as the conduction process loss calculation method, except that the start and end times of the integration are different. Eoff represents the loss energy of the shutdown process Poff represents the average power loss (active power) of the shutdown process Vds and Id represent instantaneous voltage and current, respectively Ts indicates the switching period T2, t3 indicate the start time and end time of the shutdown process Third, conduction loss In the on state, the switch tube usually flows a large current, but the on-resistance of the switch tube is very small, usually in milliohms, so the energy loss in the on state is relatively small, but it cannot ignore. Using an oscilloscope to measure conduction loss is not recommended for voltage-to-current integration because the oscilloscope cannot accurately measure small voltages during turn-on. For example, when the switch is normally turned off, the voltage is 500V, and when it is turned on, it is 100mV. Suppose the accuracy of the oscilloscope is ±1‰ (this is a very bullish indicator), and the minimum measurement accuracy is ±500mV. It is impossible to accurately measure 100mV. It is even possible that the measured voltage is negative (100mV-500mV). Since the small voltage at the time of conduction cannot be accurately measured, the energy loss error calculated by the method of integrating the voltage by the current is large. On the contrary, the current is large when turned on, so it can be measured accurately, so the current and on-resistance can be used to calculate the loss, as shown in the following formula: Econd represents the loss energy of the conduction state Pcond indicates the average power loss (active power) in the on state Id represents the instantaneous current Rds(on) indicates the on-resistance of the switch, which is given in the switch, as shown in Figure 3. Ts indicates the switching period T1, t2 indicate the start time and end time of the on state Figure 3 shows the relationship between on-resistance and current Fourth, switching loss Switching loss refers to the total energy loss, which consists of conduction process loss, shutdown process loss, and conduction loss, calculated using the following formula: Five, switching loss analysis plug-in High-end oscilloscopes usually also integrate switch loss analysis plug-ins. Because the on-state voltage measurement is not accurate, the calculation formula for the on-state can be modified. There are three main types: ● UI, U and I are measured values ● I2R, I is the measured value, R is the on-resistance, and the user inputs Rds(on) ● UceI, I is the measured value, and Uce is the voltage value input by the user to compensate for the problem of voltage and voltage uncertainty. It is generally recommended to use the I2R formula. The figure below shows the switching loss test diagram of the ZDS4000 Plus. Figure 4 Switching loss test results Summary Switching loss testing is critical for device evaluation. With a professional power analysis plug-in, the power loss of the device can be evaluated quickly and efficiently, which is simpler and more convenient than manual analysis. For MOSFETs, the I2R conduction loss calculation formula is the best choice.
