Jump to content
Electronics-Lab.com Community
Posted
I made the board with ucn5804b
I connected it with KCam 4 CNC Controller
but the step motors are not working
how can I adjust the parallel port?
how should the picture that I put look like? ??? ??? ??? ??? ??? ???
thanks
  • Replies 321
  • Created
  • Last Reply
Top Posters In This Topic
Posted
and who program is best for you?
Like I said, in my opinion EMC2. TurboCNC is easy to setup and runs on old PCs but is rather limited in capabilities. I didn't get into much detail with Mach, but EMC2 seems very impressive. It even has ladder programming (language used in PLCs).
what caind of step motors do u use?
Small inkjet printer motors. This is a small, proof of concept machine. I've bought bigger, used motors for a bigger mill or a retrofit.
Posted
Nikolas
How setting your kcam?
I made 2 boards with ucn5804b and connected it with KCam 4 CNC Controller but the step
motors are not working !
do you have working ?  ??? ???
Please how adjust the parallel port?
what windows you use?
I have windows XP Professional and an other machine have win98SE, no working in the 2 machines
thanks
i use XP
and u mas to do this
go in port setup
an do like the pic
2, 3, 4 - x-, y-, and z-axis step inputs, respectively.
6, 7, 8 - x-, y-, and z-axis direction inputs, respectively. Direction polarity depends on the motor connections. (to switch direction polarity, simply reverse the motor connections
end-for-end)
13, 12, 11 - these PC connections are used to bring the controlled machinery (i.e. X-Y table) to a "home" position. Normally open (N.O.) switches are used here.
u mast select &H378 or like in your bios see what are you have in your bios port setup
and select bedirektion in your bios
  • 2 weeks later...
  • 2 weeks later...
Posted
What are you looking for? The pdf file was a pretty good sized schematic with multiple axis. If you still need more schematics, list some specifics and we can go from there.
MP
  • 3 weeks later...
Posted
Greetings,
I would like to know what pitch of thread is on the threaded bar used & bar diameter.
or does one use any threaded bar (weight relevant to motor size) and compensate somewhere in software? As I presume there would be a difference depending on where you got it from.
Thank you.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
