MP Posted November 28, 2006 Report Share Posted November 28, 2006 Did you over heat the UCN chip? You probably need to build one of the other designs if this is the case.MP Quote Link to comment Share on other sites More sharing options...
nikolaw Posted November 28, 2006 Report Share Posted November 28, 2006 Did you over heat the UCN chip? You probably need to build one of the other designs if this is the case.MPhow do u men i over heat the UCN chip? Quote Link to comment Share on other sites More sharing options...
MP Posted November 29, 2006 Report Share Posted November 29, 2006 The chip does not have a high watt rating. If you are using steppers that consume large amounts of energy, you could damage the chip.What is the rating of your steppers? What is the rating of the power supply you used? MP Quote Link to comment Share on other sites More sharing options...
nikolaw Posted December 2, 2006 Report Share Posted December 2, 2006 The chip does not have a high watt rating. If you are using steppers that consume large amounts of energy, you could damage the chip.What is the rating of your steppers? What is the rating of the power supply you used? MPI have a problemI build another Bord but one chip broke again i use http://www.doc.ic.ac.uk/~ih/doc/stepper/others/example2/and PC power supplyWhat is the problem ??? ??? ??? :'( :'( :'( :'(How much Volts and Amperes i mast to use ???????PLEASE HELP ME Quote Link to comment Share on other sites More sharing options...
MP Posted December 2, 2006 Report Share Posted December 2, 2006 Nickolaw,What are the symptoms of the fault? When you say it is not working, what is it doing? Have you checked the power supply? Has something burned on the board? If not, have you checked all settings in the software? Have you slowed down the steps to make sure the motor is not stalled? Have you checked the pulses coming from the board? If you use a slow stepper setting, you can use LEDs to check the stepping sequences. This is a useful tool as long as you step the motors slow enough to see the individual steps with the LEDs. Don't forget to add resistors so that you do not burn out the LEDs.MP Quote Link to comment Share on other sites More sharing options...
nikolaw Posted December 3, 2006 Report Share Posted December 3, 2006 Nickolaw,What are the symptoms of the fault? When you say it is not working, what is it doing? Have you checked the power supply? Has something burned on the board? If not, have you checked all settings in the software? Have you slowed down the steps to make sure the motor is not stalled? Have you checked the pulses coming from the board? If you use a slow stepper setting, you can use LEDs to check the stepping sequences. This is a useful tool as long as you step the motors slow enough to see the individual steps with the LEDs. Don't forget to add resistors so that you do not burn out the LEDs.MPAll is ok on board only one UCN5804 broke down and i replace that UCN whit another and everything i s ok bat what can burned UCN's i Use power pc suplly is this big supply?should i use1. small power supply (i mean in A and V)2. or use fuse3.how mach is max volts and amperes of power supply what I can use for this board Quote Link to comment Share on other sites More sharing options...
MP Posted December 3, 2006 Report Share Posted December 3, 2006 The questions I posted are key questions to try and determine where the fault might be. Without answers to them, I really do not have a clue as to what is wrong.The pc power supply has quite a bit more amperage than what you need, but the power supply does not cause this problem. Something is drawing too much current. The power supply is only obliging with what is requested of it. You should find out what is causing the excessive current draw. My guess would be that you have designed a stepper board that requires more current than the UCN chip is capable of running through it. If this is the case, you should scrap the idea and build a controller board that is capable of a few amps or more.Perhaps you have chosen some wrong components that causes a draw. Can you post a drawing of your board? I tried to determine more from the pictures you posted, but they do not help for diagnostics. Post your board layout and description of parts you have used and we can try to determine if it is a component or too much current draw from the motors, etc.MP Quote Link to comment Share on other sites More sharing options...
thotrang Posted December 26, 2006 Report Share Posted December 26, 2006 All is ok on board only one UCN5804 broke down and i replace that UCN whit another and everything i s ok bat what can burned UCN's i Use power pc suplly is this big supply?should i use1. small power supply (i mean in A and V)2. or use fuse3.how mach is max volts and amperes of power supply what I can use for this board You can post your schema in here then everyone can help something for your.Best Rgds, Quote Link to comment Share on other sites More sharing options...
fever16 Posted January 14, 2007 Report Share Posted January 14, 2007 hello guys,its a very good and nice thread for 3-axis cnc.of course its a long thread of 22 pages (took me 1 whole day to read and understand) but iam able to solve my lot of doubts and questions.thanks guys (spl. MP,nikolaw and GreekPIC... others too)i saw lot of questions regarding the PCB layout.i think they arise bcz of the improper design software.the author shld have provided them in eagle etc format so that it will help while making the pcb.i'll be real thankful if some one could do that.(if someone has it already pls do post)some of my doubts that need clarification:1.in the below pic is that 5v regulator only?2.how to connect home limit switches? if we use 3 limit switches for home then overall we need 6 switches. right?3.i have some 5-6 wire stepper motors from old printers.how to know whats their voltage rating.imean 12v or 24v etcand has any one used this entire setup roughly?i just want to know how efficient it is?once again i want to thank all of u for providing some much info. Quote Link to comment Share on other sites More sharing options...
dBlaza Posted February 1, 2007 Report Share Posted February 1, 2007 Hello guys and if there-s any girls :)I'm in "maybe" little problem.I've made circuit like in example for Optoisolated stepper motor controller.It looks like thisand I took a stepper motor from the scanner which have this caracteristicsItems M42SP-7 Rated Voltage DC 12V Working Voltage DC 10.8~13.2V Rated Current/Phase 259mA 173mA No. of Phase 4 Phase Coil DC Resistance 50Ω/phase±7% Step Angle 7.5º/step Excitation Method 2-2 Phase excitation (Unipolar driving) and have 5 wires which are> red, black, brown, yellow and orangei've readed little bit about wireing of steppers and that the phases(wires) of stepper must be in some strict orderso I tryed and tryed and it doesn't work, everything that i can get out of stepper is that he vibrates or nothing.ps i have winXPpro and parallel adress is 378 checked in bios and there is something about parallel port (ECC ...)I'm sorry for my english, and I hope that someone is going to help me about itThanks to all Quote Link to comment Share on other sites More sharing options...
slikdig Posted February 2, 2007 Report Share Posted February 2, 2007 I've had a hard time finding UCN5804's recently. There either out of stock or exorbently expensive. Any suggestions on where to find them? Quote Link to comment Share on other sites More sharing options...
timnlenoir Posted February 10, 2007 Report Share Posted February 10, 2007 Try this site out http://www.cncresource.com. I shearched their site and found them for $4.50. I have not ordered from them yet but will in a few days. Here is the full link.http://www.cncresource.com/store/index.php?main_page=product_info&manufacturers_id=4&products_id=6&zenid=71c00ef3ea67643309096144674745be Quote Link to comment Share on other sites More sharing options...
steev Posted February 18, 2007 Report Share Posted February 18, 2007 exactly i too had hard time in finding those 5804 chip.either no availability or too costly for a small CNC project.so i moved for pic based stepper controller(linistepper) Quote Link to comment Share on other sites More sharing options...
new Kid Posted April 17, 2007 Report Share Posted April 17, 2007 Hi guys,I am new to this field...and wanted to build cnc for hobby...i read the thread and was facinated by this machine can do...i'm just wondering if any body have a pcb ready for soldering the parts and how much it is? and please advised for payment method and shipping. ???I hope this forum still alive :-[Thank you in advance ;Dthanks Quote Link to comment Share on other sites More sharing options...
nikolaw Posted May 7, 2007 Report Share Posted May 7, 2007 Hi guys,I am new to this field...and wanted to build cnc for hobby...i read the thread and was facinated by this machine can do...i'm just wondering if any body have a pcb ready for soldering the parts and how much it is? and please advised for payment method and shipping. ???I hope this forum still alive :-[Thank you in advance ;DthanksWhere are you from? Quote Link to comment Share on other sites More sharing options...
GreekPIC Posted May 8, 2007 Report Share Posted May 8, 2007 1.in the below pic is that 5v regulator only?There's a 7805 5V controller onboard. It can take 8-35V as an input (actually whatever voltage the steppers need) and output 5V for the UCN chips2.how to connect home limit switches? if we use 3 limit switches for home then overall we need 6 switches. right?Depending on the software you use, you can use NC or that as the switch being pressed and it will stop. You can spare some parallel port pins by wiring all three limit switches in series. The limit switches are no to be used on purpose like the home switches so you can live with that. If the machine hits a limit, you can visually check which axis it was.3.i have some 5-6 wire stepper motors from old printers.how to know whats their voltage rating.imean 12v or 24v etcNow, that's hard. Google each and every marking, serial number or brandname you see on them and try to find a datasheet.Nikolas Quote Link to comment Share on other sites More sharing options...
nikolaw Posted May 14, 2007 Report Share Posted May 14, 2007 Where i can Bay online step motors?can you tall me some web pages?????thanks Quote Link to comment Share on other sites More sharing options...
nikolaw Posted May 15, 2007 Report Share Posted May 15, 2007 heloowi need step motors please help me Quote Link to comment Share on other sites More sharing options...
GreekPIC Posted May 17, 2007 Report Share Posted May 17, 2007 Ebay, DigiKey, Mouser, RS... Quote Link to comment Share on other sites More sharing options...
trunner Posted July 10, 2010 Report Share Posted July 10, 2010 Hello,Sorry to bring this site back to life, but I think this will always be a active topic. does anyone have a copy of the files for the CW Technologies 3 Axis controller circuit? (layout, schematic, overlay etc...). All the sites that this forum points to are dead, and the internet archive has the sites but not the files:http://web.archive.org/web/20030423082423/http://users.auth.gr/~mixos/projects/pcb/pc/015/index.htmI can provide ether an email address of FTP site or email me. But if you have the files I will post them on my web server and put a link here.-Jim Quote Link to comment Share on other sites More sharing options...
trunner Posted August 10, 2010 Report Share Posted August 10, 2010 I found it by other means, as promissed here is the Plans, PCB, Layout, and diagram. I am currently working on an adapter board to make the StepGenie.com chip work instead of the 5804B (the 5804 is becomming harder and harder to find, the StepGenie is low cost and easy to find) Its a fairly simple change as the chips are so close. I will post the plans once that is done (if I ever get time).http://www.akesons.com/cw-tech/index.htm**I will host this for as long as I can** Quote Link to comment Share on other sites More sharing options...
Hero999 Posted August 10, 2010 Report Share Posted August 10, 2010 Thanks.That's the trouble with linking to external sites.I've zipped all the files and attached them to this post.Unfortunately there's still no guarantee it will stay here forever, as attachments have been lost before when the site has crashed and been restored in the past.If anyone has the files in better format, i.e Kicad or Eagle format, please post them3-axis_controller.zip Quote Link to comment Share on other sites More sharing options...
