Jump to content
Electronics-Lab.com Community
Sign in to follow this
bonanz
time delay/ hold circuit
I know this is something simple but i've done a little searching and can't find what i'm looking for and i can't work it up form scratch for the life of me....
I'm looking for digital logic circuit/gate that everything starts at 0 (low) and then if high is input, the output is high, but only for about 5 seconds, then the output goes low again, nomatter if the input stays high or goes low again.
I hope i explained it clearly, but basically the idea would be, press a button to turn on a LED or something for 5 seconds or so, if you hold the button down it goes for 5 seconds and turns off, if you press it and let go it will hold it for 5 seconds and turn off, either way once the led goes low it is ready to be turned on again.
Thanks in advance guys
Share this post
Link to post
Share on other sites
what you need is a 555 timer ic, in "non retriggerable" mode.
If you "google"( 8)) with the words "555 timer" you'll find about
54.000 results :D.The http://www.williamson-labs.com/480_555.htm
for example,looks good.
Hope i have helped a bit. ::)
Share this post
Link to post
As manotronic noticed you can use a 555 timer in Monostable mode:
The basic circuit is this:
For circuit description and how to attach a relay visit: http://www.technologystudent.com/elec1/5554.htm
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
