Jump to content
Electronics-Lab.com Community
Posted
Hi ... I have exatcly two guess to make on that topic
1st (less likely ) is the quality of the microphone
2nd ... you have inversed R6 and C4 or C3 and R5 (or R7)
making it a highpass filter that cut at 100hz instead of a lowpass filter that keep 0-100hz
Pls make sure your capacitor are at the rigth place.
I can also see you are using one led instead of two or a dual ... coud this have any impact ?
to audioguru:
finally about the input voltage, i have realised that two 9V battery is quite big for the "portable" project we are trying to make. So my guess is that i'll be ok with my current pieces and draining +- 4.5 V from a 9V battery. at the worst cases the 9V will get to 6V wich is +- 3V wich is still acceptable.
  • Replies 388
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Posted
Hmm, i have one question
What do you mean by the TL074 behaving badly when the voltage dropdown to 6V ? Because i have to find some research question on the circuit, and the (Noise/distortion/whatever happen) Vs input voltage seem an interesting subject.
Or i can just test experimentally the curve Voltage/current vs input frequency wich is a bit less interesting.
Or maybee i can analyse what happen arround the LM386 without your "rectifier"
Posted
See the sales sheet from TI. They rate the minimum supply voltage at 7V.
The circuit doesn't have a rectifier. The LM386 is a power amp for driving low impedance headphones.
Posted
from reading the small footnotes and reading other TI datasheet, i am under the impression that 7V means (Vcc+) at 7V and (Vcc-) at ground or Vcc at +- 3.5 v
how long does it take to take a 9V battery to 6V ?
Posted
Correct.
Energizer's site used to have more detail about their batteries but still show how quickly the six AAAA cells inside a little 9V alkaline cell drop in voltage with current.
Posted
HI EVERYONE!!!
JUST ASKING ONLY... HOW DOES THE CUT-OFF FREQUENCY OF 20-30HZ AT THE FILTER WAS COMPUTED??? CAN ANYONE PLEASE PROVIDE EQUATIONS FOR IT... THANKS....
-------------XOY---------------
Posted
The -3dB (half-power) highpass cutoff frequency of a capacitor and a series resistor is at the frequency where the reactance of the capacitor equals the value of the resistor.
C1 is in series with R2, which is also in series with the impedance of the mic (about 5k) in parallel with R1. So the total resistance is 5.53k and the 4.7uF of C1 equals it at 6.2Hz.
The only other series capacitor in the audio circuit is C6 which is in series with the impedance of the headphones. For two 32 ohm headphones in parallel making 16 ohms, the reactance of C6 equals 16 ohms at 10Hz.
The combination of 6.2Hz and 10Hz creates a droopy cutoff frequency of about 16Hz.
Posted
Hello Audioguru .!!!!!!! Long time no see you...coz i'm bz...thanks for all info in this forum..i successful done it..!!!! but one problem..please give me the comparison between the experimental and theoretical result of this electronic stethoscope...Urgent !!!! thanks
Posted
Hi May,
I think that the low frequency response and seal of the headphones determines the experimental result of this project. I tried pretty-good cover-the-ears headphones and heard my heartbeat loud and clear. Then I tried a pretty-good speaker and after turning down the volume to avoid acoustical feedback howling, I couldn't hear my heartbeat.
Posted
My clear Heart sound  ;D
I got a semi-shielded mic + pluged the audio jack into my computer .. then recored by jetaudio program ..
The air noise (some bad noise like air noise) are still mysterious!! I think I've a problem in something at the breadboard, that's why I'm soldering another one :)
Those noise can be heard even without connecting a mic!
Posted
Yes, i had this question.
Can you really plug the output of the lm386 to Microphone input
Or you need to go rigth before the volume control to do that ?
Your noise sound like aluminium paper being folded near the mic.
I hope this isnt the pop and crack that is tipical to opamp audioguru last described
Good luck in your project
Posted
It sounds pretty good except for the extra noises.
I don't hear much hiss (air noise?) in your recording. The extra noises are friction of the mic holder on the skin, or friction of the cable moving. It could also be noises caused by loose connections on your breadboard.
Posted
The output level from the output of the LM386 is about 200 times too high for a mic input!
Right before the volume control is about 10 times too high for a mic input.
These signal levels are speaker level and line level, not mic level. An attenuator is needed to connect them to a mic input.
The noises are from friction. Opamp noises are much lower in volume.
Posted
As you said....
I need an attenuator to reinject chipcorder output to the LM386
I need an attenuator to (optionnally) plug the output of the electronic sthetoscope to computer mic input
Both need to be somwhere arround the volume control potentiometter.
I somehow fear that there will be too much attenuator in that region
Do you need something special to prevent the normal flow from leaking in all those attenuator ?
Op-amp buffer ?
The last thing i want would be using an hardware switch to choose between mode:
- chipcorder playback
- realtime hearing
- realtime hearing + mic output
btw can the volume control be after the lm386 ?
So you can merge the chipcorder output and the lm386 output and after that, control volume ?
Posted
As you said....
Op-amp buffer ?
To avoid shorting outputs together and avoid a switch, you need an audio mixer circuit.
- realtime hearing
You can use electronic switches like Cmos transmission gates, or an audio mixer circuit.
In order to keep the LM386 and a volume control from overloading, the volume control is always ahead of the amplifier.
Posted
I undestand an opamp can overload... but how can a potentiometer overload ? does it have to do with headphone impedance ? Can i use a preset voltage divider before the lm386 then a potentiometer to reduce a bit the gain ?
What are those ? is this a way to setup transistor ?
I've seen audio mixer .. those are opamp used in addition mode rigth ?
I really do not want to go in that route... the current setup is already complicated.
I'd rather use K.I.S.S. philosophy.
All i want is preventing mylself from damaging the expensive chipcorder or the computer soundcard.
[edit] Just seen this Fet mixer project
http://www.electronics-lab.com/projects/audio/034/index.html
so basicly all i need is to add 2N3819 Junction FET
and one capacitor / resistance ?
Posted
A volume cotrol rated at 1/2W might be turned down only 10%. Then 1/10th of it would have the output current in it which could easily burn it.
A Cmos transmission gate is an electronic switch. There are many different types.
You could use that FET audio mixer if you want.
Posted
Just seen at digikey that this particular model is in sold in package of 2000+ !!
anything else to recomand ?
I guess Digikey don't sell many jFETs.
Newarkinone sell the 2N3819 in single quantities for only $.166US today.
Posted
I soldered the circuit on a veroboard .. it didn't work (cause bad joints mainly) .. anyway I'm not going to solder anything again after I was ill for 2 weeks cause of the toxic fumes :(
I'll try again with the breadboard circuit ... but I'm thinking to simplify the circuit .. I mean I'd like to give my computer a chance in amplification, so I'd like to know what is the simplest circuit attached to the MIC that makes sounds reach my computer?
I can use many programs to amplify the sound, just a matter of time :)
Posted
What kind of solder do you use, must be some old extreme stuff. Throw it away if it makes you sick and buy the new lead-free solder instead. If you got sick for two weeks from this is very serious, are you sure it wasn’t a bad pizza or something else?
Posted
I just bought a solder, which I guess had a large percent of lead .. even lead free solders can be more dangerous than solders that have lead!
I used another type, which had low amount of lead .. it was better, but same case, I had a weak respiratory system for days ..
When I was 6 years old I was used to use that type of solders and never had a problem, so I guess it's the place I solder .. it's not highly ventilated :)
Anyway, I'll be making a subdomain for that stethoscope, with shots and videos of every step in addition of medical hazards (cause we are medical students :D) ..
Posted
Mostly what you are inhaling is the burning flux from the core of the solder. Here is a link to a MSDS safety data sheet.
http://www.ee.ryerson.ca/~jkoch/MSDS_Sheets/msds%20r244l%20sn63pb37%20us%20(03oct03).pdf
You should look for the specific MSDS for your solder product. Since you are a medical student, I am sure you will appreciate the information in this MSDS sheet and the safety precautions that should be taken when soldering. Never breath the fumes. If you find this to be impossible, invest in one of the many products on the market that extract the smoke from your work station.
MP
  • 3 months later...
Posted
heyz...
im currently working on my final year project.... it wld be really helpful if anyone cld tell me which is the finalised circuit that i shld follow......something that will work... is it the stethoscope 2 that audioguru posted?
and.. if i wld like to connect the entire circuit to the computer... which means i do not use a headphone but to play the sound straight through the com.. how do i go about it? wat jack do i need to use?
thanx....
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
