rayon Posted October 22, 2003 Report Share Posted October 22, 2003 Good day...i have build your 200W audio amplifier and it work well. but when i connect it to my tape deck and touch the chassis it is humming why? I could not get 150nf or 1.8nf ,so i put in 0.15uf ceramic cap for 150nf and .0018uf for 1.8nf and it work. but why the humming pleaseProject Link: http://www.electronics-lab.com/projects/audio/013/index.html Quote Link to comment Share on other sites More sharing options...
metal Posted October 29, 2003 Report Share Posted October 29, 2003 Hi ;)The chassis may be connected to the tape head wire shielding ,so when you touch it the speakers start humming,because you form a source of 50Hz or 60Hz mains hum as you being human,and affected by electromagnetics,as antennas are,just to make the image closer. Quote Link to comment Share on other sites More sharing options...
rayon Posted November 1, 2003 Author Report Share Posted November 1, 2003 HEY... ;D..Metal what's up ,,How can i stop the Humming...? ???where and the amplifier can i ground to stop the hum..Bye-one love ,,,i am from jamaica.. Quote Link to comment Share on other sites More sharing options...
Guest ksd Posted November 3, 2003 Report Share Posted November 3, 2003 Sir, please give how to troubleshoot the hums (different types) in audios Quote Link to comment Share on other sites More sharing options...
mozikluv Posted November 7, 2003 Report Share Posted November 7, 2003 :)hi there,you mentioned you used ceramic caps, try replacing those with mylars or polypropylene caps.there are several sources of hum in an amplifier, 1. poor grounding connection2. defective capacitors3. inadequate power supply filter4. poor ground line lay-out5. ground line loop6. external input humQuest. 1. on a stand alone, meaning no signal input, do you hear any hum from your amp?Quest. 2. does your input ground share the same line with your power line ground? Quote Link to comment Share on other sites More sharing options...
balong Posted March 13, 2006 Report Share Posted March 13, 2006 hello!!! id like to ask some question about caps. i have a problem about polyester capsbecause this caps is not widely abailable here in the philiphines!! if i replace it with mylar or ceramic caps. is that ok!! Quote Link to comment Share on other sites More sharing options...
audioguru Posted March 13, 2006 Report Share Posted March 13, 2006 A polyester cap is a mylar cap or is also known as a "green cap" but I have seen oriental "brown caps" that are the same. Quote Link to comment Share on other sites More sharing options...
