er3na Posted December 5, 2003 Report Posted December 5, 2003 Hello there. Regarding the keys finder circuit, I find the circuit image to be a bit blurry. Some parts of it are quite hard to see. I would really appreciate it if U could help me with a clearer image of the schematic. Really need it for my project.Thank you. :) ;) :D ;DProject Link: http://www.electronics-lab.com/projects/misc/002/index.html Quote
EDY Posted December 5, 2003 Report Posted December 5, 2003 I hope this will do the trick ;DMike you can use this image too but check it for any errors :DClick the image for full resolution. Quote
mixos Posted December 5, 2003 Report Posted December 5, 2003 Great work EDY !! You won an ION MOTOR CONTRUCTION GUIDE ;D :Ion_motor.pdf Quote
EDY Posted December 5, 2003 Report Posted December 5, 2003 Tanx Mike :) :) :)Its been a long time since I won anything :-X;DSince I haven't read the text (only few words to be precise) I have to ask what exactly is a usage of it since I don't have a space ship? ;D ;) :) 8)Cheers Quote
mixos Posted December 6, 2003 Report Posted December 6, 2003 It's just for educational purposes :D ! But... it is used also to ionize your room.. so you don't have to buy a commercial ionizer to keep your room's air fresh ;D! Quote
EDY Posted December 6, 2003 Report Posted December 6, 2003 Nice ;)I've just read the whole text and it is rather interesting ;DOnly one question remains:What can I use for 10KV power-up supply? :o Quote
mixos Posted December 6, 2003 Report Posted December 6, 2003 Are you ready to build it :o ??Here you will find some great Hight Voltage Power Supplies using a TV's transformer:http://www.geocities.com/CapeCanaveral/Lab/5322/hv2.html Quote
EDY Posted December 6, 2003 Report Posted December 6, 2003 No. Not yet.My brain is to tired right now of all learnig I have to do for universitiy, and learning about electronics circuits is on hold till further notice becouse of that >:( :( :'(But I'm most probably ask my few friends who have more expirience in these things to build me a hihg voltage transformer. 8)I will most probably build it becouse I have chronic bronhitis (don't know if this is the right expresion) and the way I figure it if I make this ionizer it will help me breathe easier during the winter days (becouse heat from the radiators makes air more dry and thus its hevier to breathe and ionizer fresens it) :PHere I am talking about my medical problems. I wonder what's next ??? ;)Cheers Quote
er3na Posted December 9, 2003 Author Report Posted December 9, 2003 Thanx so much EDY. U've been a great help! ;) btw, how do we get the fizzle that we need to produce for the buzzer? Does screeching two keys together help? Or is it possible to just make some hand claps to trigger the buzzer? ::) ??? Quote
bogdan Posted January 31, 2004 Report Posted January 31, 2004 a good thing would be to create a SMD version of the circuit. maybe find a beeping cheychain, take it's guts out and put this in. Quote
jazcannon Posted October 8, 2004 Report Posted October 8, 2004 ;D I am building this circuit as a project and I would really appreciate it if you could tell me which piezoelectric buzzer would be used. I have all of the other parts but this one is really annoying me. Thank you very much. Jazcannon. ;D Quote
audioguru Posted October 8, 2004 Report Posted October 8, 2004 Hi Jazcannon,Welcome to our forum.You don't want an actual piezo buzzer, which would have a built-in oscillator, you need a piezo transducer. The circuit already has an oscillator and a buzzer won't work as a microphone. Bad translation, I guess.I don't know where you are but my Canadian Newarkinone catalog has many of them. Select one with a resonant frequency of 3KHz to 4KHz.What on earth is a fizzle? Another bad translation.I think that you must make a whistle type of sound that is near the transducer's resonant frequency. Quote
lapsap Posted May 28, 2005 Report Posted May 28, 2005 after i connected it to a battery, the buzzer started trigger, wheter i whistle or other sound, nothing is change. is it i use the wrong buzzer? how to make sure i get the correct buzzer? Quote
audioguru Posted May 28, 2005 Report Posted May 28, 2005 Hi Lapsap,Welcome to our forum. ;DYou don't want a buzzer, the circuit needs a piezo transducer. D4, C7 and D3 are supposed to stop the transducer from whistling after about 1 second.The circuit is supposed to trigger from nearly any fairly high-pitch sound, not just a "fizzle", whatever that is. ;D Quote
lapsap Posted May 28, 2005 Report Posted May 28, 2005 thx,what the different between piezo buzzer and piezo transducer? and also whats the different between selfdrive (3 terminal) and external drive (2 terminal) which one am i suppose to use? Quote
Guest Alun Posted May 28, 2005 Report Posted May 28, 2005 A piezo buzzer has a built in oscilator to drive it.A buzzer element has three terminals, ground, dirive and feedback, if you connect the output to the output of an amplifier and the feedback to the input it will form and oscillator and make a sound at its resonant frequency.http://www.avxcorp.com/docs/masterpubs/piezo.pdfhttp://www.murata.com/catalog/p15e6.pdfHere's the circuit, I got it from the first link, it's a basic common emitter amplifier with the drive terminal connected to it's output and the feedback connected to the input.EDIT:I've just noticed this circuit doesn't need a buzzer, it needs a transducer, in this case just connect the feedback and drive togeather and connect them to the output. Quote
lapsap Posted May 28, 2005 Report Posted May 28, 2005 icic, thx for the information, i hope it work perpectly after getting the transducer Quote
Guest Alun Posted May 28, 2005 Report Posted May 28, 2005 I forgot to say, the only difference between a piezo transducer and piezo buzzer element it a buzzer element has an extra feedback lead, a transducer just has drive and ground leads. Just connect the feedback and driver together and use the buzzer element as a transducer. Quote
lapsap Posted May 30, 2005 Report Posted May 30, 2005 i m still very blur with the piezo thing. from the sitehttp://www.murata.com/catalog/p15e6.pdfit say that external drive: 2 terminalselfdrive : 3 terminal and what i found out from website that sell these component say thatpiezo buzzer or transducer each of them is also having selfdrive and external drive.so which one should i use.one more thing, do u mind to explain the circuit how it actually work? i m still quite blur with it, especially the part N1...N3, from what i know is that the inverter work in the digital part, change from 1 to 0, or 0 to 1. how it can be configure to be amplify?thx for your help, i have just started learning about electronic. Quote
audioguru Posted May 30, 2005 Report Posted May 30, 2005 Hi Lapsap,Just get a two-wire piezo transducer designed for external drive. Our project uses it as a microphone then drives it to make a sound. A CD4069 inverter is just a pair of push-pull complimentary Mos transistors. It makes a pretty good linear amplifier with the negative feedback provided by the resistors from output to input. The feedback makes it self-bias, if the output DC voltage tried to be too low then it feedsback into the input which forces the output up to a voltage about half the supply voltage where its Mos transistors have the most gain. ;D Quote
Guest Alun Posted May 30, 2005 Report Posted May 30, 2005 I hope this picture settles the matter. ;DAs long as you don't use a piezo buzzer with an internal driver this circuit will work. You can use either a 2 or 3 lead piezo transducer in this circuit, if you use the 3 lead variety then just connect the feedback to the drive. Quote
audioguru Posted May 30, 2005 Report Posted May 30, 2005 I think a 2-wire transducer will make a more sensitive microphone since its useful area is larger and in a single lighter-weight piece. ;D Quote
Guest Alun Posted May 30, 2005 Report Posted May 30, 2005 I think there will be very little difference between the two, but I agree the two wire unit will be very slightly better and is a more appropriate choice. I was just pointing out that you can also use a three terminal device if it's more convenient to get hold of. ;D Quote
lapsap Posted June 1, 2005 Report Posted June 1, 2005 Posted by: Alun Posted on: May 28, 2005, 02:20:24 PMInsert QuoteI forgot to say, the only difference between a piezo transducer and piezo buzzer element it a buzzer element has an extra feedback lead, a transducer just has drive and ground leads. Just connect the feedback and driver together and use the buzzer element as a transducer.back to my old question, whats the different between transducer ans buzzer?so it means that this transducer will act as a mic and then become a speaker to produce sound? Quote
audioguru Posted June 1, 2005 Report Posted June 1, 2005 A piezo buzzer usually has a transistor oscillator in it and therefore cannot be used as a microphone. Its oscillator will conflict with the oscillator in this project when it is supposed to be a speaker.Quote: Our project uses it as a microphone then drives it to make a sound. Quote
