Jump to content
Electronics-Lab.com Community
Sine wave power inverter
Guest Kasamiko
Guest Kasamiko
I've been planning to construct a power inverter at least 500 watts,230 VAC,sinewave or quasi-sinewave output..
My friends told me that using an Inverter with a square wave output is not good to power some home appliances?? ::)
thanks for any info.
Link to comment
Share on other sites
Kasamiko,
Some information on Inverters:
There are 3 major types of inverters - sine wave (or "true" sine wave), modified sine wave (actually a modified square wave), and square wave.
Sine Wave
A sine wave is what you get from your local utility company and (usually) from a generator. This is because it is generated by rotating AC machinery and sine waves are a natural product of rotating AC machinery. The major advantage of a sine wave inverter is that all of the equipment which is sold on the market is designed for a sine wave. This guarantees that the equipment will work to its full specifications.
Some appliances, such as motors and microwave ovens will only produce full output with sine wave power.
A few appliances, such as bread makers, light dimmers, and some battery chargers require a sine wave to work at all.
Sine wave inverters are always more expensive - from 2 to 3 times as much.
Modified Sine Wave (quasi-sine)
A modified sine wave inverter actually has a waveform more like a square wave, but with an extra step or so. A modified sine wave inverter will work fine with most equipment, although the efficiency or power will be reduced with some. Motors, such as refrigerator motor, pumps, fans etc will use more power from the inverter due to lower efficiency. Most motors will use about 20% more power. This is because a fair percentage of a modified sine wave is higher frequencies - that is, not 60 Hz (or 50 Hz, depending upon your location) - so the motors cannot use it.
Some fluorescent lights will not operate quite as bright, and some may buzz or make annoying humming noises.
Appliances with electronic timers and/or digital clocks will often not operate correctly. Many appliances get their timing from the line power - basically, they take the 50/60 Hz (cycles per second) and divide it down to 1 per second or whatever is needed. Because the modified sine wave is noisier and rougher than a pure sine wave, clocks and timers may run faster or not work at all. They also have some parts of the wave that are not 50/60 Hz, which can make clocks run fast.
Items such as bread makers and light dimmers may not work at all - in many cases appliances that use electronic temperature controls will not control. The most common is on such things as variable speed drills will only have two speeds - on and off.
Square Wave
Very few but the very cheapest inverters any more are square wave. A square wave inverter will run simple things like tools with universal motors with no problem - but not much else. These are seldom seen any more except in the very cheap or very old ones.
MP
Link to comment
  • 4 weeks later...
  • 3 weeks later...
Guest Kasamiko
That setup is not practical I think..If you want a 300 watts inverter, you must have an amplifier that is capable of at least 300 watts also..
One thing this inverter excel, it can produce a true sine wave, not just a modified square or triangular waves.. ;D ;D
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
