steven Posted January 21, 2004 Report Share Posted January 21, 2004 ;) this simple plasma tube exsperiment ive biult before consists of a few photo flash tubes from the old phased out pocket cameras in australia. now there is 4 tubes but only 2 are from pocket cameras, the other 2 are exenon flash tubes , these 2 were not from any camera ive autopsied, now one of the camera flash tubes is longer than the other.This longest tube i used to form the botton edge of a tryangle ,the 2 rxenon tubes i solder one to each end and bent down to complte the tryangle/then from that corner where the 2 exenon tubes meet and are solderd like the other ,i solder one more camera flash tube. the setup now looks like a tryangle with a tube sticking out one corner .Now to power them i used a flyback driver circiut, originally a transformer driver circiut used for the vortex canon circiut on carl williams robotic site i think it was, now in the circiut instead of a transformer and the rest of the circiut i stop at that and used a small unusual looking flyback like transformer, that was linked to a flyback , and it had its own hv ouput lead . now withe the tube setup i solderd a wire to one corner and from there to another corner , the flyback or transformer driver circiut itself, i made the following modifications, i changed all the 1n4007 diodes to uf4007 diodes, they are 10 nanosecond high speed diodes if i remember corectly . Now all the flashtubes have there trigger coil wires removed . now comes the good part, when i fire it up i get arc streamers moveing in the tubes but when i make some adjustments, the moveing arcs suspend , they freeze into the shape i got sine wave shape ,sawtooth shape and a strait line still arc none move unless i adjust the circiut more then ill get a square wave shape nice and still as it holds that shape. when i make another adjust ment the square wave starts untill i re adjust it, then its still. now with the straitline arc i bring a magnet near it and it starts to bend . while makeing adjustments the radio down stairs starts to sound like its being tuned throught the short wave band . and at another point of adjustment it jams the radio completely / every station across the dial is being efected. Now here comes the wierd part at another point of adjustment , one of the exenon tubes appear to have a light purple glow around it and the transparency seems different and that tube appears to look like its colapseing like its melting and a clear like fluid runing from one end to the other i hope to conduct this exsperiment again soon , i canot properly exsplain it but for a moment i thought the tube was invisible. no damage was done ,after i switched the circiut off the tube i can see more easy again . Quote Link to comment Share on other sites More sharing options...
gsmaster Posted January 21, 2004 Report Share Posted January 21, 2004 Cool! ;) ;) I didn't understand the construction of the whole thing... When you will do it again take some photos! Quote Link to comment Share on other sites More sharing options...
mixos Posted April 6, 2004 Report Share Posted April 6, 2004 Here comes more photos: Quote Link to comment Share on other sites More sharing options...
