jdelectro Posted February 9, 2004 Report Posted February 9, 2004 Please I need a datasheet for an obsolete audio moduleSTK401. Please note, there are many SKT401-xxxx but thismodule has only the SKT401, see attachmentAny help will be apreciatedJose [email protected] ??? Quote
mixos Posted February 9, 2004 Report Posted February 9, 2004 STK401 is pin compatible with the next models STK401-020 and STK401-050. The difference (with a fast view at datasheets) is the output power and max supply voltage.Are you searching a specific info for STK401-000?http://www.datadart.com/al/sanyo/STK401-020.pdfhttp://www.datadart.com/al/sanyo/STK401-050.pdf Quote
geniussheikh Posted February 10, 2004 Report Posted February 10, 2004 First of all my friend the name of the IC is stk401 not skt401ok. Click on the following link . YOu will get the datasheet of yoiur ic.http://www.datadart.com/al/sanyo/STK401-020.pdfGenius Sheikh. Quote
