Jump to content
Electronics-Lab.com Community
Sign in to follow this
sickness
metal detector
It is highly unlikely that you will be able to do this. If it was sold as a toy, it will probably not use components that will allow you to tweak more sensitivity from the circuitry. You would literally be rebuilding the device. But that is only speculation on my part without being able to see the circuit. Perhaps you can map out the components from the circuit board. This is called reverse engineering. If you can do this, you would be able to know what you have to work with. Don't worry about component values at first, just draw how the components connect to each other.
MP
Share this post
Link to post
Share on other sites
Here is a good place to start, containing a lot of info on metal locators.
Lots of schematics and even a forum.
http://www.thunting.com/cgi-bin/geotech/pages/common/index.pl?page=metdet&file=schematics.dat
Good luck!
Ante ::)
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
