billy Posted February 20, 2004 Report Share Posted February 20, 2004 Hi all !After I have bought my brand new usb logic analyzer :D(have a look : http://www.usb-instruments.com/hardware-ant8.html)which I need most, because digitals is my main hobby, I am thinking of building a simple pc oscilloscope as well, rather than buying a new one, because it is not critical for my needs. I want to write my own software (in Delphi) because most of the existing projects I have found are working only with win95/98 (not 2k/xp) and they don't have a professional interface, rather trivial I'd say.So I have done a search on the net on this subject and I found the following projects (one to three stars * for complexity according to my opinion).***http://kudelsko.free.fr/index2.htm***http://alternatezone.com/electronics/dsoamk3.htm**http://www.chocbar.demon.co.uk/ **http://www.ee.washington.edu/conselec/CE/sp95reports/guterman/final/scope1.htm*http://scopeonpc.tripod.com/*http://www.geocities.com/lptscope/hw.htmlIf somebody knows anything more, just let me know, the net is vast indeed :)From all the above I have liked http://www.geocities.com/lptscope/hw.htmland I have a question :It uses the ADC0820 8-bit A/D which has an input of maximum +5volts, but it says that you can use a voltage divider in order to expand this range. Has anyone any idea how you can do that ? I prefer +-50volts because it is good for most applications (for instance PSU testing).Thanks and I am waiting for your ideas ! 8) Quote Link to comment Share on other sites More sharing options...
billy Posted February 20, 2004 Author Report Share Posted February 20, 2004 Found some more :**http://www.leonardo.caltech.edu/~ee5x/eecs52/projects/scope/scope.htm**http://www.fpga4fun.com/digitalscope.html Quote Link to comment Share on other sites More sharing options...
billy Posted February 20, 2004 Author Report Share Posted February 20, 2004 And finally this is the best of all :I have found schematics of a pc oscilloscope that works withthe PICOScope software !!! http://free-ri.hinet.hr/abacus-ri/from this thread :http://groups.google.com/groups?q=pico+scope&hl=el&lr=&ie=UTF-8&oe=UTF-8&selm=aflbt6%242akr%241%40as201.hinet.hr&rnum=4but I still want to expand the 5v input to 50 v... :-\ Quote Link to comment Share on other sites More sharing options...
ante Posted February 20, 2004 Report Share Posted February 20, 2004 Here is an attenator for pc oscilloscope that is used for soundcard input but it will probably be possible to apply in this case. The site is in Norwegian but the schematic is pretty simple. http://home.online.no/%7Esondred/Gamle%20sider/attenuator.htmAnte ::) Quote Link to comment Share on other sites More sharing options...
fatoota Posted February 26, 2004 Report Share Posted February 26, 2004 hii just have an idea about what you said of +5 volt as a maximam i/p.i think you can not give the pc souncard very high voltage or it will burn, so you have to use attenuators, not neccessarily a voltage divider and you may enter the attenuation level as a data to your software.that is all and i thank you that you started this interesting subject and money saver. Quote Link to comment Share on other sites More sharing options...
MP Posted February 26, 2004 Report Share Posted February 26, 2004 You are correct. Most PC devices will not allow more than 5 volts. Some cards have over voltage protection, but I would not use a higher voltage as a test to find out if yours has protection. You should decide what your highest voltage will be. Is it 5 Volts Pk-Pk?, 10 volts Pk-Pk? When you have this figured out, then you just use a small transformer to drop it down. Sound is an AC voltage, so transformers work great for these. There are several types used for telephone equipment that will work fine for you. perhaps you want a 2:1 or similar.MP Quote Link to comment Share on other sites More sharing options...
fatoota Posted February 27, 2004 Report Share Posted February 27, 2004 with the name of allahi found this link that may be useful http://www.ee.washington.edu/conselec/CE/sp95reports/guterman/final/scope1.htm#hard :)sherief-egypt Quote Link to comment Share on other sites More sharing options...
mixos Posted February 27, 2004 Report Share Posted February 27, 2004 This topic has been also discussed here:http://www.electronics-lab.com/forum/index.php?board=13;action=display;threadid=58;start=msg153#msg153 Quote Link to comment Share on other sites More sharing options...
edu38 Posted May 19, 2004 Report Share Posted May 19, 2004 Billy:please can upload traslation to eng of this site http://free-ri.htnet.hr/abacus-ri/.I can`t understand anything......regards from buenos aires Quote Link to comment Share on other sites More sharing options...
Guest Kasamiko Posted May 20, 2004 Report Share Posted May 20, 2004 Is there any links for a simpler circuit without using ADC?? Quote Link to comment Share on other sites More sharing options...
ante Posted May 20, 2004 Report Share Posted May 20, 2004 Kasamiko,My earlier post http://home.online.no/%7Esondred/Gamle%20sider/attenuator.htm is not using any ADC, it Quote Link to comment Share on other sites More sharing options...
Guest Kasamiko Posted May 20, 2004 Report Share Posted May 20, 2004 OK,but got some question about it..1. Where in my sound card i'm going to connect it? line-in?2. The sound card is STEREO(of course) what particular channel i put it in?Thanks again.. Quote Link to comment Share on other sites More sharing options...
ante Posted May 21, 2004 Report Share Posted May 21, 2004 Kasamiko,How you connect it to the soundcard depends on which software you use. Most of them use the line-in for this but even the mic-input is sometimes used. Both channels is used to dual channel scope software. There is also some software for frequency measuring if you just want to count the waves and not look at them ;D which uses the same inputs.Ante ::) Quote Link to comment Share on other sites More sharing options...
Guest Kasamiko Posted May 22, 2004 Report Share Posted May 22, 2004 Thanks ANTE.. ;D I'm planning to use the Winscope and would like to "VIEW" the waveform of various Power inverter that we've been discussed here.. 8) 8) Quote Link to comment Share on other sites More sharing options...
ante Posted May 22, 2004 Report Share Posted May 22, 2004 Kasamiko,I hope to see some screen dumps of the waveforms on this forum soon then! Take care and don Quote Link to comment Share on other sites More sharing options...
Guest Kasamiko Posted May 22, 2004 Report Share Posted May 22, 2004 Just wait and see.. ;) ;)give me some time... ;D ;D Quote Link to comment Share on other sites More sharing options...
