FireFly Posted March 2, 2004 Report Share Posted March 2, 2004 I've been looking into selecting a one-piece square bridge rectifier for the 30V/3A power supply project. There seems to be lots of these like every other component type! Generally, they seem to have rather heavy voltage/amperage handling abilities.What is the downside to using a bridge with significantly higher ratings than required besides slightly higher cost and larger physical size?Would a bridge with just adequate specs put out more heat than one with much greater than required specs? Quote Link to comment Share on other sites More sharing options...
Ldanielrosa Posted March 3, 2004 Report Share Posted March 3, 2004 A higher rated bridge will more easily tolerate voltage transients and startup surges. Also it may have a slightly lower voltage drop. Quote Link to comment Share on other sites More sharing options...
