Jump to content
Electronics-Lab.com Community
4N25 Schematic check
Hey guys.
I plan on controlling 2 fans, 1 Intake and 1 exhaust, for cooling in a computer case. I want to have one DPST switch that when in one position will cause an 8v (eventually a temperature controlled circuit instead) to power only the Intake fan and when in the second position, both fans will receive a full 12v.
I decided to use 4N25 optoisolaters simply because it would isolate the 2 fans completely but I've never used something like this before.
I made this schematic in Circuitmaker2000 and it seems to work on there but I really have no idea what the tolerances of this circuit would be or if maybe I'm doing something wrong.
If you guys have any suggestions, please lemme know.
Link to comment
Share on other sites
Well see, thats why I had to come here to ask. I can't make sense of anything on the datasheet as far as limits goes. I'm just not into the lingo :(
The fans will probably be drawing no more then 1.5 amps total (the exhaust will be 2 high cfm fans) and I'm really not sure if that will burn up the chips, which means I'd need to find a high current version of the 4N25.
Link to comment
I really don't understand what the optoisolators are for. Isolating the fans? Isolating them from what, or isolating what from them? If you were using the output of some sensitive IC to drive the fans, then I could see it, but a simple switch does not need isolation from the fans, nor do the fans need isolation from the switch!
Get rid of the optoisolators, and use the switch to switch the intake fan between the 8v source and the 12v source. Don't make things more complicated than they need to be.
BTW, all of the computer case fans I have around here have a current draw of 0.1 A or so. Much less than what you estimated. Check the labels of your fans; the current should be printed on it.
Link to comment
It is always a good idea to use an optoisolator when connecting a device capable of EMF to a computer.
But sec brings up a good point. Is the 5V source coming from other switching circuitry or is this just part of the power supply?
At the very least, you should include some power diodes across the terminals of the fans so the EMF does not cause a momentary short on your computer power supply. Then you could just use the switch as is. If the 5V and switch is representative of a microcontroller or some other similar circuitry, then you must have the optoisolator or other type of protection.
MP
Link to comment
Well see, I'm not just switching from 12v to 8v. Lemme see if this helps:
Switch Position 1:
-Intake Fan powered by a temperature control circuit. Approximately 6-10 volts varrying between 25-40 degrees celcius will be applied to the intake. The 8v in the schematic was just a place holder so I could test the circuit in my software.
-Exhaust Fan is off, no power.
Switch Position 2:
-Intake AND Exhaust fans are both receiving a full 12 volts.
My original reasoning for using the 4N25's was because I couldn't figure a way to controll both fans with one switch but have one fan controlled by 2 sources and the other off/on without crossing the power lines somewhere. With the isolators, I don't have that issue.
Link to comment
Here is a control circuit (switch) that can be used with most any small PNP transistor such as 2N3906. When the resistor to the base is connected to ground (or close) the transistor is in an "ON" state.
The diagram shows the switch used to turn on a relay but it could be used the same for a motor such as used in a small fan.
MP
Link to comment
Thanks a lot MP. I've considered all the options and I think that for the sake of simplicity, I'm going to go with 2 DT Relays connected to a DPST switch. Here's an image of the schematic I've figured out.
The only thing different from the final schematic is the variable resistor to the LM317 will be a 500ohm thermistor.
One thing I'm not sure about but have heard about is back EMF for the relays. Apparently I should toss a Diode in somewhere?
Link to comment
Yes, just like the example in my last post. That is what the diode is there for. This is also a relay driver. By the way, how much current does the relay require to turn on the coil? Do I recall that the switch is not really a switch? That it is another device? You should check to be sure you have enough current from this device to power the relay coils.
MP
Link to comment
Amps, your revised circuit shows 12V relay coils powered by only 5V.
Use 5V relays.
When you turn-on the computer, it will be cold and the switch or temp.-controller will apply only 8V to 1 fan. Will it start running on this low voltage? Most fan controllers apply full voltage for a moment to get the fan started then ramp the voltage down to a lower running voltage.
As MP stated in his 3rd reply, use anti back-EMF diodes across the fans.
Link to comment
Oops, thats a small error on my part, I meant to put 5v relays in, just mis-clicked.
Typical ambient temperature in my case will be about 15-20 degrees celcius. The way I have the resistance set up, that means that the controller will put out about 4.5-5v. These fans spin up at around 3.5v and it won't take long for them to hit the operating temperature of about 25-30 degrees.
You mention putting a diode across the fan but I've never had to do that for a project such as this before. Can you explain? I've got the 2 across each coil on the relays.
Link to comment
You will have the same EMF effect when the motors for the fan come on like what you have when the coil of the relay is energized. It is a good plan for all motor type circuits. You would not see a difference in the way your circuit operates. It is for protection, like adding a fuse.
MP
Link to comment
That's right, MP. Please let me elaborate.
The motor has coils of wire around a core, just like a relay. They are inductors. When you energize an inductor then a magnetic field is built-up around the core. When you remove the power source then the collapsing field induces a high voltage across the coil. That is the principle that some DC-DC step-up converters use.
This high voltage is the reverse of the applied voltage and could damage a driver transistor. In Amp's circuit, the high voltage could spark and cause pitting of the relays' contacts or jump to adjacent circuitry causing damage there.
A reverse-connected diode arrests the induced voltage.
Link to comment
Ok, thats something I'll consider but I'll have to do more research. The motors in the circuit are just place holders for computer fans (circuitmaker didn't have a fan). I'm pretty sure that most computer fans have protection against that sort of thing otherwise everytime I switched on one of my many fans, my power supply would hiccup ;D
Link to comment
Some computer fans do have the diode built into them. If you can reverse the direction of the motor by switching the wires, then it does not. If you can switch the polarity of the wires and it will not run, then there is a diode built into the fan.
MP
Link to comment
MP,
If a back-EMF protection diode is built into a fan then it would be in parallel, not in series. So if you connected it backwards then the diode would be forward-conducting across the power supply which may blow-up the diode and/or the power supply.
Amps,
Maybe you misunderstood my explanation of the reason for having a protection diode across a fan or relay coil: without a protection diode then a high voltage will occur across the fan and its driver, not the power supply, when the fan is turned-off.
Link to comment
Now where in my post did you read me to mean the diode was in series?
Yes, if you have a fan with this protection, it is parallel, but no it will not blow anything up. Your power supply can handle this. The diode protection and current limiting in the power supply will pull the current down to nothing.
If you buy a replacement cooling fan for your PC from radio shack, they are not going to expect you to know to wire in a diode.
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
